Crystal Error 7512 - Authorization failed
Geoff,
Your Vantage user will not work with ODBC. You will need to use sysprogress
for both user and pass unless you set something else up.
Aaron Hoyt
Vantage Plastics.
Sent: Wednesday, December 22, 2004 4:36 PM
Subject: [Vantage] Crystal Error 7512 - Authorization failed
I am trying to use Crystal and our recently installed ODBC setup to
run reports on the Vantage databases.
When I select my Database in Crystal through the ODBC drop box and
select Mfgsys61 it asks me to enter my user and password. It
accepts them and then allows me access to the databases. I can see
all of them, and I can select them and see the fields within them.
I can add them to my Crystal report.
BUT... when I try to preview the report or run the report I get
Crystal error 7512 (Access denied(Authorization failed)).
Can anyone suggest what might be wrong? I've been told that this is
a common error to get when you aren't using the right user/password
combo at the login box, but once you get past that box this
shouldn't be coming up.
The user/password combo I'm using is my own and I have security
rights to see all of the data in these files.
Help!?!
Geoff
Yahoo! Groups Links
Help!?!
Geoff
