It is not locking you out due to isolation level, rather denying you
access.
Access denied (authorization failed)(7512)
Make sure that your ODBC setup username and password have read access to
your database. Use the Test Connect button when setting up ODBC. If you
can't get the test connect to work, none of your reports are going to
work either.
See Epicor documentation for setting up ODBC connections.
Sent: Tuesday, October 07, 2008 8:30 AM
Subject: [Vantage] Crystal report memo table ODBC error 7512
All,
I'm new to Vantage and keep getting an error that states:
ODBC error: [datadirect-technolgies][ODBC PROGRESS driver][PROGRESS]
Access denied(authorisation failed)(7512)
It appears to be locking the table for some reason. I have called
out "read uncommitted" in my ODBC DSN default isolation level.
I'm only using the "memo table" and grabbing the key1, memoDate,
memoUserID, MemoDesc, and MemoText fields.
Any help would be greatly appreciated.
Thanks!
John Peters
Sign Productions Inc
access.
work either.
All,
Thanks!
John Peters
