Did you add the user sysprogress with the password sysprogress to the
database?
(This is not a vantage user but a progress user).
This is necessary with progress 9.1A and up.
Technical support of Epicor has a little program that can add the user for
you.
Ronald van der Linden
Macroscoop
Sent: maandag 26 maart 2001 18:06
Subject: [Vantage] 5.0 ODBC
I am trying to configure an ODBC datasource for eManufacturing. I
can test the datasource successfully. However, when I go to Excel,
Access or any other ODBC compliant application, I can define the
tables that I wish to use but when it goes to access the data in
those tables, I get the following error:
[MERANT][ODBC PROGRESS driver][PROGRESS]Access denied(Authorisation
failed)(7512)
The error message is consistent between all of the applications that
I have tried, (Authorisation failed) error number (7512). I can't
find any documentation on this error message anywhere.
Any ideas would be appreciated.
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
linked your email address to a yahoo id to enable access.
database?
you.
Macroscoop
failed)(7512)
