I am linking InvcMsc to InvcHead. I am the getting the correct records. I can match Certain Months but some months I cannot. My feeling is that there is a charge or something I am missing.
Â
Jonathan LangÂ
Oil Rite Corporation
Sr. Network Administrator
Ph: (920) 682-6173 Ext: 126
Fax: (920) 682-7699
Â
Jonathan LangÂ
Fax: (920) 682-7699
--- On Wed, 7/22/09, Dale Schuerman <dale.schuerman@...> wrote:
Subject: RE: [Vantage] Crystal Reports Invoice
Date: Wednesday, July 22, 2009, 3:58 PM
Â
Check you linkages.
If you are linking InvcMsc to InvcDtl (or something like that) and
totaling the InvcDtl. DocExtPrice.
If there are 3 InvcMsc records you are also getting three InvcDtl
records and your subtotaled DocExtPrice will be multiplied by three
times. Etc....
If this is the case Invoice lines with one or zero InvcMsc records
should be correct.
Hope this helps
Dale E. Schuerman
Senior Consultant
Epicor Certified Consulting Partner
RAM Software Systems, Inc.
972-669-0763 x233 (voice)
972-669-9603 (fax)
mailto:dale.schuerman@ ramsys.com
<BLOCKED::blocked: :mailto:dale.schuerman@ ramsys.com> (email)
http://www.ramsys com <BLOCKED::blocked: :http://www.ramsys com/>
(website)
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Jonathan Lang
Sent: Wednesday, July 22, 2009 3:34 PM
To: vantage@yahoogroups .com
Bill,
I don't want to edit ARForm. I want to create a report that shows the
Invoice Totals per Month, and Year. The problem is my amounts are not
correct.
Tables I am using:
InvcHead, Customer, InvcDtl, and InvcMsc.I have an Outerjoin on InvcMsc.
Jonathan Lang
Fax: (920) 682-7699
--- On Wed, 7/22/09, Bill King <bking@jandbindustri al.com
To: "'vantage@yahoogroup s.com <mailto:%27vantage% 40yahoogroups. com> '"
<vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> >
Date: Wednesday, July 22, 2009, 3:19 PM
we have done a ton of edits on this form to customize for our business
needs. in regards to your issue, i put running totals for line charges,
line misc charges, surcharges, and order misc charges to be reset at
change of group header #1 (invoice number). as a check i added a water
mark to read components of invoice and invoice total do not match if
they don't, suppressed if they do. this gives us the flexibility to
itemized the charge type and still maintain the docinvamt that matches
the system so paper and screen agree.
BILL R. KING
J&B Industrial Services
(806).776.4409 Office
(254).592.4397 Cell
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On
Behalf Of Jonathan Lang
Sent: Wednesday, July 22, 2009 3:05 PM
Subject: [Vantage] Crystal Reports Invoice
Good afternoon,
I am having a huge problem getting the correct Invoice amount.
What I am trying to do is get the Amount from each line of every
Invoice. This has to match the Invoices we print out from Invoice Entry,
under Payment Schedule at the bottom of the ARForm, Amount.
I thought I could get this information from Invdtl.DocExtPrice, but to
no avail. I also added in with Invdtl.DocExtPrice a MiscCharge that does
add to the Amount but also to no avail.
I would appreciate any help.
Thank you,
Jonathan Lang
Fax: (920) 682-7699
The information contained in this message is intended solely for the
individual to whom it is specifically and originally addressed. This
message and its contents may contain confidential or privileged
information. If you are not the intended recipient, you are hereby
notified that any disclosure or distribution, or taking any action in
reliance on the contents of this information, is strictly prohibited.
We have taken precautions to minimize the risk of transmitting software
viruses, but we advise you to carry out your own virus checks on any
attachment to this message. We cannot accept liability for any loss or
damage caused by software viruses.
This message (including any attachments) is intended only for
the use of the individual or entity to which it is addressed and
may contain information that is non-public, proprietary,
privileged, confidential, and exempt from disclosure under
applicable law or may constitute as attorney work product.
If you are not the intended recipient, you are hereby notified
that any use, dissemination, distribution, or copying of this
communication is strictly prohibited. If you have received this
communication in error, notify us immediately by telephone and
(i) destroy this message if a facsimile or (ii) delete this message
immediately if this is an electronic communication.
Thank you.
Attention:
This email message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
This email message has been scanned for Viruses and Content and cleared
by MailMarshal SMTP
For more information go to http://www.ramsys com
