Hey, Everybody:
Would like to create a parameter that would allow a Fiscal Year and Fiscal Period range, e.g., user can enter 2013 period 1 thru 2014 period 5
Having a little trouble putting the logic together in Crystal Reports.
Thanks.
I'd consider doing a little trickery in Crystal.Â
Make a string formula that combines the FY & FP called "myFYFP".Â
Something like:Â ToText({FY},0,'') + '-' + ToText({FP},0,'')
So your records in Crystal would have another "column" now to utilize called "myFYFP"
2014-01
2014-02
2014-03
2014-12
Now you use parameters within Crystal to filter your results. One param would be "Start_FY-FP" and "End_FY-FP". The user would input or select the appropriate FY-FP range. And your results will be filtered appropriately when you use them in the Select Expert.
…. where {@myFYFP} >= {Start_FY-FP} and {@myFYFP} <= {End_FY-FP}
HTH.
Sent: Thursday, January 22, 2015 7:17 PM
Subject: [Vantage] Crystal Reports logic for FiscalYear and FiscalPeriod
Hey, Everybody:
Thanks.
Sent from my iPhone
On Jan 23, 2015, at 12:33 PM, sanfranc415@... [vantage] <vantage@yahoogroups.com> wrote:
Thanks for the prompt reply. I've gone ahead and created the formula, it display like you noted, and the parameters request the range in the format year-period, but the results are skewed and don't match up with the parameters.
For example:
It's returning all of 2014 if you enter 2014-11 and 2015-01
Please advise.
Thanks.
Did you apply the params in Select Expert?
Sent: Friday, January 23, 2015 12:34 PM
Subject: [Vantage] Re: Crystal Reports logic for FiscalYear and FiscalPeriod
For example:
Please advise.
Thanks.
