Crystal to SSRS
I am transferring several reports from Crystal to SSRS. One thing I noticed is that in the Crystal when we run a report wit multiple groups, on the left side of the screen it allowed you to expand or close these groups accordingly. Can you do this in SSRS as well for the end user?
Mr. Wil79: If you run the report directly from IIS then yes you can do that as well as enable the drill down features of SSRS.
However, from the Epicor preview pane - I don’t know how to enable that.
DaveO
I’m no expert on this but I found the workaround was to create the report shortcut/menu item as a url link, within Epicor and then link direct to the SSRS report rather than using the Epicor embedded report interface. Means you executing within SSRS rather than Epicor.
If I recall this is in line with the embedded SSRS training.
