On the Opportunity/Quote Entry (and Sales Order Entry) header screens is a field for Customer ShipTo. Right-clicking on the field gives you the ability to open a slide-out panel for Customer ShipTo Entry. I’m trying to add a UD field to that screen.
Adding the UD field to the Customer ShipTo Maintenance Slide-Out Panel (in Application Studio for Customer Maintenance) doesn’t put it there. Not sure what I’m doing wrong.
Are you still using the system event that opens the panel?
You’ll probably have to copy the stock event, set the trigger as an override for the original event, then set the Layer property in app-open to whatever custom layer you created.
I have experienced this. If there is a big enough latency when “sliding out” the layer doesn’t get called and only returns base. We have had users that are not on site have layers never apply for this exact reason, where others on site it works just fine.
Our solution was to convert the slideout to a pop-out to make it “pop-out” reliably with the new layer.
For those who want to experience this. If you go into your dev tools and increase your latency to something high, it will always trigger this. Someone on my team already contacted support and documented this, but I am not sure where it is.
