Thanks Patty! Works perfect! :)
Â
Dustin Biniek
UMC, Inc.
DustinB@...
----- Original Message ----
Sent: Tuesday, September 16, 2008 11:46:26 AM
Subject: [Vantage] Re: Customization - Sheet Wizard Question (8.03.4XX)
Open your dashboard and right click on the query in the tree view.
Go to the Publish tab and publish the tablename.JobNum
Go to the Filter tab and choose tablename.jobnum = dashboard browse
Another window will pop up, just click ok
When you added this dashboard to your Job Tracker, you need to go
through the Embed Dashboard wizard. You should choose to Subscribe
JobHead.JobNum
If you have the Epicor Tools User Guide, you can find all the details
starting on page# 103
Patty Buechler
Â
Dustin Biniek
UMC, Inc.
DustinB@...
JobHead.JobNum
Patty Buechler
--- In vantage@yahoogroups .com, melissa hietala <kevmel822@. ..> wrote:
> I've added a custom sheet to Job Tracker and attached a Dashboard
via the Embedded Dashboard Panel wizard. When I pull a job into job
tracker, the dashboard currently displays a list of ALL the jobs in
the system, when really i just want the info to be displayed for the
current job in job tracker.  Is there something that I might
be overlooking in setting up the Embedded Dashboard Panel Wizard or
is there something that I may need to adjust within the dashboard
itself?
> Thanks,
> Dustin Biniek
> UMC, Inc.
> DustinB@...
