Cutlist Help Blank Title 82499
Thank You for the info. Got that set up now and it is working like we need.
Gene
--- In vantage@yahoogroups.com, "advantage" <advantage@...> wrote:
> There won't be. The "CutList" table isn't really a table. You have to create the relationships CutList.Company>JobAsml.Company; CutList.JobNum>JobAsml.JobNum; CutList.AssemblySeq>JobAsml.AssemblySeq
> From: gmack110256
> To: vantage@yahoogroups.com
> Sent: Tuesday, September 08, 2009 10:08 AM
> Subject: [Vantage] Re: Cutlist Help
> I tried to set up Using the Cutlist Table as the parent and Job assembly as the child. There dosen't seem to be a "Key" field I can use.
> Any Ideas?
> Gene
> --- In vantage@yahoogroups.com, "Charlie Wilson" <foamdesigncsw@> wrote:
> > How did you set up the relationships in the RDD?
> > ~Charlie
> > _____
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> > gmack110256
> > Sent: Tuesday, September 08, 2009 7:39 AM
> > Subject: [Vantage] Cutlist Help
> > I am reposting this again today. We are trying to get the Cutlist report
> > changed in Vantage. I have brought in the Job assembly and Subassembly
> > Tables into the RDD. What we are trying to do is get the report to let us
> > show the part number and decsritption that the material being pulled into
> > the report will be used to make. from what I have seen in the group someone
> > made this work in June of last year and I am trying to find out what was
> > done to make it work. As of now I cannot get any information to pull into
> > the report.
> > Thank You
> > Gene
I am reposting this again today. We are trying to get the Cutlist report changed in Vantage. I have brought in the Job assembly and Subassembly Tables into the RDD. What we are trying to do is get the report to let us show the part number and decsritption that the material being pulled into the report will be used to make. from what I have seen in the group someone made this work in June of last year and I am trying to find out what was done to make it work. As of now I cannot get any information to pull into the report.
Thank You
Gene
~Charlie
_____
gmack110256
the report.
Thank You
Gene
Any Ideas?
Gene
> ~Charlie
> _____
> gmack110256
> the report.
> Thank You
> Gene
Any Ideas?
Gene
> ~Charlie
> _____
> gmack110256
> the report.
> Thank You
> Gene
