Dashboard error when deploying - where to fix?
Hi all. Where do I look to fix this error? I’m redeploying our dashboards after the upgrade, and all were fine except one which threw the following error:
--------compile errors------------
Error: CS0234 - line 13 (13) - The type or namespace name ‘Proxy’ does not exist in the namespace ‘Ice’ (are you missing an assembly reference?)
** Compile Failed. **
I’ve gone into each of the two BAQ’s and the dashboard itself (don’t believe there are any customizations on this) but I don’t know where to go to fix this. You guys are awesome, so I bet you do! Please share. :slight_smile:
And happy Friiiiiday!!!
Erin
What SQL version do you have ? Kinetic requires atleast SQL Server 2017…
SYA
Try to recycle the app pool and re login.
