I having an issue in a few of my dashboards, the highlighting does not always appear to work. The dashboard i’m working with now I highlight the job number that matches the job number of the grid above it. It always work when in the dashboard developer but when I run test application it will randomly not highlight the matching job.
Hi, when making changes to the dashboards it is always worth copying them and creating a new one with a new version number. I use V1, V2 etc on the end, as this forces the creation of a new DLL and has solved quite a few issues for me.
I had this issue, in my case I had several rules spread across 3 different linked datasets. In my case, I found I had to supply some Notify events to keep everything properly rendered. It may not be relevant to your situation.
