I am having trouble opening a dashboard record in our Test environment. I haven’t pushed the dashboard to Live yet.
I go to Dashboard Maintenance and search for my dashboard. It’s in the list, and I select it. However, my dashboard isn’t loaded on the form when it returns to the Maintenance window. It flashes for a second, then disappears. I’m stuck making any headway on this. I’ve done all the obvious stuff like restart my machine etc. Other dashboards open up, just not the one I want…
Good morning,
First make sure your BAQ feeding the dashbaord returns the correct data. Just run it by itself (with filters if needed) from BAQ designer.
Next check, are there any customizations on your dashboard, or on Dashboard Maintenance? Try opening Customization Maintenance and reviewing the forms that have been customized there. It will also show any issues with your customized forms.
Also, try turning on developer mode, and making sure you are running the base version of dashboard maintenance.
Good luck!
