Data access
I think that you can connect to progress using VB.Net.
Although I did not try this VB.NET, I wrote a program in VB6 that
connects to progress db using ODBC.
The connection string is "Provider=MSDASQL.1;Persist Security
Info=False;User ID=sysprogress;Password=sysprogress;Data
Source=Your_DataSource_In_ODBC
Sent: Friday, January 13, 2006 12:08 PM
Subject: [Vantage] Re: Data access
Yes, I did. But, VB.NET will only connect to SQL and JET
databases. Must be some kind of internal restriction. I guess they
want you to pony up for the full Visual Studio product.
Mike
--- In vantage@yahoogroups.com, "Gerard Wadman" <gwadman@s...> wrote:
> Did you try using a DSN connection string in VB.Net?
> Ie:
DSN=Vantage;HOST=servername;PORT=####;DB=mfgsys;UID=username;PWD=pass
wor
> d
Behalf
> Of mikehaynes99
> Sent: Thursday, January 12, 2006 10:47 AM
> More on my problem. I have a fair amount of experience using
Access
> to view/manipulate data so getting to the Vantage tables isn't
much
> of a problem. Yes, I did run into the > 32 indexes on the
customer
> file. I'll look into the suggestion of a 'view'. My original
> problem which I wrote about here was that I couldn't view the
table
> data from the invchead and invcdet tables. I kept getting an ODBC
> fail message when I tried to peek into the table data with
a 'select
> *' statement. With much experimentation I've determined that
there
> is a field within the table that causes the error. If I stay away
> from the repsplit field then I can select and view all other
fields
> in the header table, at least. I've not tried that in the
detail.
> Since I've discovered that I can get to 99% of the data I can
finish
> my project which is developing an Access application to track and
> pay commissions to our salespeople. Vantage doesn't work for us
in
> that area. I also tried to use VB .NET but was disappointed to
> learn that that product will only access SQL and Jet databases.
> Does anyone know if the full Visual Studio .NET product would
> connect to Progress via ODBC?
> Thanks to all who responded.
> Mike
> Sure Alloy Steel Corp.
> --- In vantage@yahoogroups.com, "Brian Stenglein"
<bstenglein@c...>
> wrote:
> > Mike,
> > Welcome to the board. We are still using 6.1, but I use Access
a
> > lot. We had problems with using the Customer Table, because of
> too
> > many indexes, so we had to create a view, as mentioned
> previously.
> > I'm not sure if this is the problem you are having, but if it
is,
> > Tech Support will have instructions for you on setting up the
> view,
> > it was pretty easy at least it was for 6.1.
> > If the problem you are having is not due to too many indexes,
can
> you
> > elaborate on the error? Have you talked to support about it?
I'm
> > really interested in hearing more about the problem and solution
> that
> > you come up with.
> > Thanks,
> > Brian Stenglein
> > Clow Stamping Co.
> > --- In vantage@yahoogroups.com, "mikehaynes99" <mikeh@s...>
wrote:
> > > Hello All,
> > > First time poster and brand new 8.0 user here. I have only
> > recently
> > > discovered this resource and I have lots of Vantage questions
> but
> > the
> > > one most pressing for me right now is how do all of you (if
any
> of
> > you
> > > do) get to your Vantage tables outside of Vantage? I have
used
> > > Microsoft Access to view some table data but this doesn't work
> for
> > all
> > > the tables. Specifically, I need to get to the Invoice Header
> and
> > > Detail tables but due to some peculiar data structure I get an
> > error
> > > when I try to link to these tables.
> > > Maybe I already have the necessary tools and I just don't know
> it
> > > because our administrator back office type training was non-
> > existant.
> > > Can anybody help me with this and/or be willing to talk to me
> about
> > > how this can be done?
> > > Thanks,
> > > Mike Haynes
must
> have already linked your email address to a yahoo id to enable
access. )
Builder
> and Crystal Reports and other 'goodies', please goto:
> YAHOO! GROUPS LINKS
> * Visit your group "vantage
> <http://groups.yahoo.com/group/vantage> " on the web.
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/> .
_____
YAHOO! GROUPS LINKS
_____
Hello All,
First time poster and brand new 8.0 user here. I have only recently
discovered this resource and I have lots of Vantage questions but the
one most pressing for me right now is how do all of you (if any of you
do) get to your Vantage tables outside of Vantage? I have used
Microsoft Access to view some table data but this doesn't work for all
the tables. Specifically, I need to get to the Invoice Header and
Detail tables but due to some peculiar data structure I get an error
Maybe I already have the necessary tools and I just don't know it
because our administrator back office type training was non-existant.
Can anybody help me with this and/or be willing to talk to me about
Mike Haynes
Try OpenOffice. OpenOffice 2.0 has a decent database program called Base.
Unlike access, it doesn't have restrictions on the number of indexes per
table. It isn't perfect, and not quite as pretty as Access, but very
functional for designing queries.
http://www.openoffice.org/
We use it for our Progress and MySQL databases.
Chris Gitzlaff
Major Industries, Inc.
mikehaynes99
Sent: Tuesday, January 10, 2006 12:51 PM
Subject: [Vantage] Data access
Hello All,
Mike Haynes
Yahoo! Groups Links
I would created a sql pass through query in access. If you can link a table
you should be able to created a pass through query. Use your same odbc
connection like you did when you connected to the database and on the query
type EX. "select * from pub.part" (assuming you have a progress db). The
.part is the table. In your case you would want something like "select *
from pub.Invchead" This should return all records in the DB. Large Tables
can take awhile.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
mikehaynes99
Hello All,
Mike Haynes
SPONSORED LINKS
Manufacturing software Membership database software Database mortgage
software
Pda database software Database management software Database marketing
software
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage>
" on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
_____
You can also create a "view" in the progress database. Someone here
recommended this before and it worked great with Access! How I
understand views, is that they are basically a consolidated table of the
data you actually want. Someone here can probably explain them better.
The problem I had is that Access could not look at a table with more
than 32 indexes. The view solved this problem and also alerted us to
another issue with our row sizes being too long! It must have happened
when we used VB Forms to insert extensive notes. You can create views
using the SQL Explorer Tool. You also have to know a little of the SQL
language as well.
Joe Luster
Network Administrator
Cold Jet, LLC
513-831-3211 ext. 308
513-831-1209 FAX
<http://www.coldjet.com>
_____
Of Olson, Brian
Sent: Tuesday, January 10, 2006 2:09 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Data access
table
query
Tables
can take awhile.
Of
mikehaynes99
Hello All,
Mike Haynes
have
and
<http://groups.yahoo.com/group/vantage/files/> >
SPONSORED LINKS
mortgage
software
marketing
software
_____
YAHOO! GROUPS LINKS
" on the web.
Service
_____
_____
YAHOO! GROUPS LINKS
_____
Mike,
Welcome to the board. We are still using 6.1, but I use Access a
lot. We had problems with using the Customer Table, because of too
many indexes, so we had to create a view, as mentioned previously.
I'm not sure if this is the problem you are having, but if it is,
Tech Support will have instructions for you on setting up the view,
If the problem you are having is not due to too many indexes, can you
elaborate on the error? Have you talked to support about it? I'm
really interested in hearing more about the problem and solution that
you come up with.
Brian Stenglein
Clow Stamping Co.
--- In vantage@yahoogroups.com, "mikehaynes99" <mikeh@s...> wrote:
> Hello All,
recently
the
you
all
error
existant.
> Thanks,
> Mike Haynes
More on my problem. I have a fair amount of experience using Access
to view/manipulate data so getting to the Vantage tables isn't much
of a problem. Yes, I did run into the > 32 indexes on the customer
problem which I wrote about here was that I couldn't view the table
fail message when I tried to peek into the table data with a 'select
*' statement. With much experimentation I've determined that there
from the repsplit field then I can select and view all other fields
in the header table, at least. I've not tried that in the detail.
Since I've discovered that I can get to 99% of the data I can finish
pay commissions to our salespeople. Vantage doesn't work for us in
Mike
--- In vantage@yahoogroups.com, "Brian Stenglein" <bstenglein@c...>
wrote:
> Mike,
too
previously.
view,
you
that
> you come up with.
> Thanks,
> Brian Stenglein
> Clow Stamping Co.
> > Hello All,
> recently
but
> the
of
> you
for
> all
and
> error
it
> existant.
about
> > Thanks,
> > Mike Haynes
Mike,
VS.NET will access any data source addressable from all things MDAC (read
ODBC, DAO, ADO, etc...) including Progress. It's also accessible from JDBC
for free...
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
http://www.aspacia.com/
mikehaynes99
Sent: Thursday, January 12, 2006 7:47 AM
Subject: Spam [Vantage] Re: Data access
More on my problem. I have a fair amount of experience using Access to
view/manipulate data so getting to the Vantage tables isn't much of a
problem. Yes, I did run into the > 32 indexes on the customer file. I'll
look into the suggestion of a 'view'. My original problem which I wrote
about here was that I couldn't view the table data from the invchead and
invcdet tables. I kept getting an ODBC fail message when I tried to peek
into the table data with a 'select *' statement. With much experimentation
I've determined that there is a field within the table that causes the
error. If I stay away from the repsplit field then I can select and view
all other fields in the header table, at least. I've not tried that in the
detail.
Since I've discovered that I can get to 99% of the data I can finish my
project which is developing an Access application to track and pay
commissions to our salespeople. Vantage doesn't work for us in that area.
I also tried to use VB .NET but was disappointed to learn that that product
Does anyone know if the full Visual Studio .NET product would connect to
Progress via ODBC?
Mike
wrote:
> Mike,
> Welcome to the board. We are still using 6.1, but I use Access a lot.
too
previously.
> I'm not sure if this is the problem you are having, but if it is, Tech
view,
you
that
> you come up with.
> Thanks,
> Brian Stenglein
> Clow Stamping Co.
> > Hello All,
> recently
but
> the
of
> you
for
> all
and
> error
it
> existant.
about
> > Thanks,
> > Mike Haynes
Yahoo! Groups Links
The "repsplit" column in the OrfHed table causes the same problem in
Access, DB Visualizer and in SQL Viewer.
Of Michael Barry
Sent: Thursday, January 12, 2006 12:22 PM
Subject: RE: Spam [Vantage] Re: Data access
Mike,
(read
JDBC
for free...
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
Of
mikehaynes99
I'll
peek
experimentation
view
the
detail.
area.
product
Progress via ODBC?
Mike
wrote:
> Mike,
too
previously.
view,
you
that
> you come up with.
> Thanks,
> Brian Stenglein
> Clow Stamping Co.
> > Hello All,
> recently
but
> the
of
> you
for
> all
and
> error
it
> existant.
about
> > Thanks,
> > Mike Haynes
have
and
Yahoo! Groups Links
SPONSORED LINKS
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Database
+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA>
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=Da
tabase+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
Database mortgage software
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Data
base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Database+
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg>
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
tabase+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
Database marketing software
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu
facturing+software&w2=Membership+database+software&w3=Database+mortgage+
software&w4=Pda+database+software&w5=Database+management+software&w6=Dat
abase+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
YAHOO! GROUPS LINKS
What is JDBC?
Mike
--- In vantage@yahoogroups.com, "Michael Barry" <mbarry@b...> wrote:
> Mike,
MDAC (read
from JDBC
> for free...
> Michael
> Michael Barry
> Aspacia Systems Inc
> 866.566.9600
> 312.803.0730 fax
Behalf Of
> mikehaynes99
Access to
of a
file. I'll
invchead and
to peek
experimentation
the
and view
that in the
> detail.
finish my
that area.
that product
connect to
> Progress via ODBC?
> Mike
> wrote:
> > Mike,
a lot.
> too
> previously.
is, Tech
> view,
> you
I'm
> that
> > you come up with.
> > Thanks,
> > Brian Stenglein
> > Clow Stamping Co.
wrote:
> > > Hello All,
> > recently
> but
> > the
> of
> > you
used
> for
> > all
> and
> > error
> it
> > existant.
> about
> > > Thanks,
> > > Mike Haynes
must have
Builder and
> Yahoo! Groups Links
> What is JDBC?
http://java.sun.com/products/jdbc/
Think ODBC for Java. Well, except that JDBC can use ODBC sources too...
Ie:
DSN=Vantage;HOST=servername;PORT=####;DB=mfgsys;UID=username;PWD=passwor
d
Of mikehaynes99
Mike
wrote:
> Mike,
too
previously.
view,
you
that
> you come up with.
> Thanks,
> Brian Stenglein
> Clow Stamping Co.
> > Hello All,
> recently
but
> the
of
> you
for
> all
and
> error
it
> existant.
about
> > Thanks,
> > Mike Haynes
YAHOO! GROUPS LINKS
Mike
> Ie:
wor
> d
Behalf
> Of mikehaynes99
Access
much
customer
table
a 'select
there
fields
detail.
finish
in
> Mike
<bstenglein@c...>
> wrote:
> > Mike,
a
> too
> previously.
is,
> view,
can
> you
I'm
> that
> > you come up with.
> > Thanks,
> > Brian Stenglein
> > Clow Stamping Co.
wrote:
> > > Hello All,
> > recently
> but
> > the
any
> of
> > you
used
> for
> > all
> and
> > error
> it
> > existant.
> about
> > > Thanks,
> > > Mike Haynes
must
access. )
Builder
> YAHOO! GROUPS LINKS
