The Select All button on the Run Data Fix tab doesn’t seem to work. I can manually select the records to fix (put a check in the box). The UnSelectAll button will un-check them all. Then clicking Select All, and only the ones I had previously manually selected will be re-selected.
Thought I could get around it by using a Paste Upade with just a column full of TRUE. But Paste Insert is disabled in Data Fix Workbench grid.
aidacra
(Epicor Employee: Nathan your friendly neighborhood Support Engineer)
3
I’m suspecting this is data fix specific. Let the analyst know that sent the fix to you know that you are running into this, and they’ll report it to the appropriate team to get a recompile of the data fix.
