margin-right:0in;
margin-left:0in;
font-size:12.0pt;
font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-637136958 code
font-family:“Courier New”;}
#ygrps-yiv-637136958 pre
margin:0in;
margin-bottom:.0001pt;
font-size:10.0pt;
#ygrps-yiv-637136958 tt
#ygrps-yiv-637136958 span.ygrps-yiv-637136958cat
#ygrps-yiv-637136958 span.ygrps-yiv-637136958ct
#ygrps-yiv-637136958 span.ygrps-yiv-637136958HTMLPreformattedChar
font-family:Consolas;}
#ygrps-yiv-637136958 p.ygrps-yiv-637136958attach, #ygrps-yiv-637136958 li.ygrps-yiv-637136958attach, #ygrps-yiv-637136958 div.ygrps-yiv-637136958attach
margin-right:0in;
margin-left:0in;
font-size:9.0pt;
font-family:“Arial”, “sans-serif”;}
#ygrps-yiv-637136958 p.ygrps-yiv-637136958bold, #ygrps-yiv-637136958 li.ygrps-yiv-637136958bold, #ygrps-yiv-637136958 div.ygrps-yiv-637136958bold
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
font-weight:bold;}
#ygrps-yiv-637136958 p.ygrps-yiv-637136958green, #ygrps-yiv-637136958 li.ygrps-yiv-637136958green, #ygrps-yiv-637136958 div.ygrps-yiv-637136958green
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:#628C2A;}
#ygrps-yiv-637136958 p.ygrps-yiv-637136958replbq, #ygrps-yiv-637136958 li.ygrps-yiv-637136958replbq, #ygrps-yiv-637136958 div.ygrps-yiv-637136958replbq
margin:3.0pt;
font-size:12.0pt;
#ygrps-yiv-637136958 p.ygrps-yiv-637136958ad, #ygrps-yiv-637136958 li.ygrps-yiv-637136958ad, #ygrps-yiv-637136958 div.ygrps-yiv-637136958ad
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-637136958 p.ygrps-yiv-637136958underline, #ygrps-yiv-637136958 li.ygrps-yiv-637136958underline, #ygrps-yiv-637136958 div.ygrps-yiv-637136958underline
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-637136958 span.ygrps-yiv-637136958yshortcuts
#ygrps-yiv-637136958 p.ygrps-yiv-637136958ad1, #ygrps-yiv-637136958 li.ygrps-yiv-637136958ad1, #ygrps-yiv-637136958 div.ygrps-yiv-637136958ad1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-637136958 p.ygrps-yiv-637136958ad2, #ygrps-yiv-637136958 li.ygrps-yiv-637136958ad2, #ygrps-yiv-637136958 div.ygrps-yiv-637136958ad2
margin-right:0in;
margin-bottom:7.5pt;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-637136958 p.ygrps-yiv-637136958underline1, #ygrps-yiv-637136958 li.ygrps-yiv-637136958underline1, #ygrps-yiv-637136958 div.ygrps-yiv-637136958underline1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
text-decoration:underline;}
#ygrps-yiv-637136958 span.ygrps-yiv-637136958yshortcuts1
font-family:“Verdana”, “sans-serif”;
font-weight:bold;}
#ygrps-yiv-637136958 span.ygrps-yiv-637136958yshortcuts2
font-weight:normal;}
#ygrps-yiv-637136958 span.ygrps-yiv-637136958EmailStyle36
font-family:“Calibri”, “sans-serif”;
color:#1F497D;}
#ygrps-yiv-637136958 .ygrps-yiv-637136958MsoChpDefault
font-size:10.0pt;}
_filtered #ygrps-yiv-637136958 {
margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-637136958 div.ygrps-yiv-637136958WordSection1
font-family:Symbol;}
font-family:Wingdings;}
#ygrps-yiv-637136958 ol
{margin-bottom:0in;}
#ygrps-yiv-637136958 ul
Yes. Depending on what you want to pull the data form you can first create a query form another table (if it is pulling data from another table for the options) and then have the updateable field reference that. Or you can key in a list of values.
On the Update tab under the General Properties tab go to the advanced column editor configuration in the bottom right.
From there you can set the editor info on the field.Â
Change the editor type to drop-down list.
To just key in a drop-down value list chose  “data from†as custom values then enter the data below.Â
If you are referencing from another table you have to make the other query first then “data from†BAQ.
