RC2020
(Miguel Lopez)
1
Is there a way to have 2 date ranges to be selected on a BAQ?
For instance, I have Apply Date and Invoice Date on Invoice Tables, and I want to be able to switch between the 2 on a the date range criteria.
Is it possible or do I have to create a separate dashboard?
Thanks in Advance.
Miguel Lopez
Hally
(Simon Hall)
2
What about having a to and from date parameters for each of the two dates (i.e. From Invoice Date/To Invoice Date and From Apply Date/To Apply Date)?
RC2020
(Miguel Lopez)
3
I can do that but it looks wierd and I have to check ignore if blank, I don’t know if I can put a check box to select one or the other.
Or is there a way to add text to let the user use one or the other.
Thank you.
Miguel
Hally
(Simon Hall)
4
I haven’t used E9 for a while, but in 10 there is ignore if empty check box on the parameters.
The other option is set some large out-of bounds defaults so that if the user doesn’t change them one date parameters does not effect the other.
