Hi Jeff,
You should store the labor rate somewhere to avoid hard-coding these labor
rate values. I would start with customizing your Job Department Maintenance
screen and add a JCDept.Number01 bound text field to the screen. Then,
populate each job department with a labor rate.
When that is done, create a pre-processing BPM on the EmpBasic.Update method
that will look up the value from the JCDept table and add the Number01 value
to the labor rate field in EmpBasic table.
When you get the customization finished, let me know and I can walk you
through the code details of the BPM if needed.
Ross
jplehr
Sent: Wednesday, June 02, 2010 8:03 AM
Subject: [Vantage] Default value in a field
Vantage 8.03.408A
Don't even know where to start on this one. Looking for some detailed
direction.
The particular scenario is in Employee Entry. You have the drop down option
to select the Home Department. I would like the Labor Rate to populate the
appropriate field based on the department selected.
Anyone. Thanks much.
Jeff
Ross
jplehr
Vantage 8.03.408A
direction.
Jeff
