Brian,
Don't know if this will help or not, but I'm going around installing the 5.1
client on machines with 3.0. In order to get them both to run, and they
will run simultaneously, is this:
1. Map the network drive to the 5.1 share
2. Disconnect the network drive for the 5.0 share
3. Run unregocx on your 5.0 network drive (or 3.0 in our case) from the 5.1
share
4. Install the 5.1 client
5. Run vcopydll.exe from the 5.1 server
6. Change the shortcut line to v:\vantage\vantage.exe
v:\vantage\vantage.vtg
7. Map the drive for the 5.0 share
8. Reinstall the 5.0 client
Only snafu I could see in this is the 3.0 client has a lot less installed
than the newer versions. I do have 3.0 and 5.1 on different servers and I'm
also using different drive letters - R for 3.0 and V for 5.1. What the
heck, can't hurt to try. Like I always say - "It doesn't work now so I
can't screw it up any more" :-)
Rick
share
Rick
