DMR and Rework
Welcome to the group @MicromaticQuality !
Irrelevant, but I was a SQE for 3 years here before switching to Epicor admin full time.
Good question - I’ve been doing this for nine years and only questioned it a couple weeks ago:
AFAIK, it’s manual and tedious.
  1. Make DMR
  2. Make job for part 123
  3. Add material to job; material is also part 123 (1 per)
  4. Accept DMR to job material
  5. ???
Meaning that step 5 is up to you. You could receive the finished part to stock, or I suppose to the job that started it all. I’ve never tried that, but I could see it.
Umm… no? Maybe?
Do you have a dev environment to test in?
I believe that dispositioning the DMR (in full) will close the DMR. So step 4 above would do it.
You imply something that has irked me forever, that DMRs close WAYYYYY before the problem is solved. Dispositioning to rework or RTV will close the DMR but the work is not done. We are still waiting on a supplier credit or the rework job to complete. I had to make a dashboard (BAQ) to keep tabs on it all.
