I know that you can do things with the command line to run DMT. I don’t know all of the capabilities. I have a process in which we run a dashboard with three tabs, and I have a button to write info from those tabs to the appropriate CSV files. Then I have a playlist file made up that I can run to run all three of those.
My question is, can I use a command line to run the playlist so I can just double click on a .bat file and run it without opening DMT? Or better yet, put that command line into a button on the dashboard to run it within Epicor?
It’s not saving that much time, but it’s the little things in life you know? Haha
