DMT for Multi Plant
Good Morning,
We have 3 plants / 1 company setup and we use DMT significantly.  It seems to me that plant is required in the dataset where it is needed.  I think if it is not in the dataset it is not needed.
For example, since i have one company, all plants share same sales orders.  Therefore, if I were to import a set of sales orders, order header (OrderHed) data will not require plant.  Order release data (OrderRel) would require the plant that is expected to satisfy the demand.  But it doesn't mean that the order was necessarily input in that plant.
Part also doesn't require plant.  However, Part plant records are required to detail how a plant handles the part record.
Hope this helps a bit?
Nancy
For companies that have multi-plants under one company. We are wanting to DMT data into only one of the plants and not the others, but some of the templates do NOT have a 'plant' field to specify just the one plant. Is there a way to do this?
#ygrps-yiv-1917391623 P.ygrps-yiv-1917391623b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1917391623 LI.ygrps-yiv-1917391623b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1917391623 DIV.ygrps-yiv-1917391623b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1917391623 TABLE.ygrps-yiv-1917391623b1e7fd89-0279-4ffe-a16a-1f1bcba0d537Table { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1917391623 DIV.ygrps-yiv-1917391623Section1 { }
Most templates can support the Plant column even if it is not in the template builder.
Also if needed you can create a user that only has access to a particular plant and process all of the imports with this user if needed.
On 19 Oct 2015, at 22:40, detroitrdwings91@... [vantage] <vantage@yahoogroups.com> wrote:
Stephen Edginton (Beng) | Solutions & Technical Director
Mobile:  +44 7734 858415
DDI:  +44 121 314 1179
Main:  +44 (0) 121 314 1170
Web:  www.dotnetit.co.uk
Dot Net IT Limited, One St Kenelm Court, Steel Park Road, Halesowen, B62 8HD, United Kingdom.
DotNetIT
Epicor Platinum Partner
Epicor Alliance Partner
There are quite a few that do not have Plant (or Site) like Operation, Department, Workforce, and more.    Inventory related tables will usually have Plant.  I’m trying to recall if I saw any tables in E10 that referred to it as Site rather than Plant so if E10 it might be good to look for both.
-Todd C.
Sent: Monday, October 19, 2015 4:39 PM
Subject: [Vantage] DMT for Multi Plant
