You can link directly to tables in progress using Access.
Epicor has a document called V800odbcKit.rtf
That describes how to setup an ODBC Connection.
I'll email you the file.
I have successfully pushed data into progress database.
When pushing data YOu can't push more than 7000 records. I don't kow
where this limit is imposed? PRogress? ODBC Connection? Access?
Suggestions anyone? I just broke my queries up to work around it.
I have pushed parts, BOM, Vendors, etc. Just have to ensure you enter
correct IDs and link everything together.
DEFINATELY BACKUP before doing this stuff.
good Luck
Lyndon
good Luck
Lyndon
--- In vantage@yahoogroups.com, <lonwiksell@...> wrote:
> Just about everything is possible in Access. When you say build, copy
> and search tables do you mean to build a table in Access or to build the
> table in Vantage? We do not update the Vantage tables or Progress
> database from Access because Epicor said it would void support. This is
> strange because I've done it with other systems and it works. Here, at
> ROM, we do the ODBC link to the Progress tables and download the tables
> to the Access database (the Access database engine where the tables are
> stored is called Jet - if you wanted to store more data that Jet can
> hold, which is a 2 gig limit, you could build the tables in Microsofts
> SQL with Access as the front end). We have some 40 Access databases
> that we use for quote and order acknowledgements, hard and soft
> production schedules, packing slips, shipping labels and on and on.
> About the one thing we have not done is print a BOM.
> Lon A. Wiksell
> ROM Corporation
> Belton, MO
> 816-318-8000
> Of Bruce Butler
> Sent: Friday, May 11, 2007 1:27 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Dynamically building tables in Access
> I want the ability to develop BOM reports. Is it possible to
> dynamically build, copy, & search tables (aliases) within Access? Has
> anyone done this? Is there a BOM report available from access /
> crystal?
> Thank you,
> Bruce Butler, IT Manager
> Knappe & Koester, Inc. <http://www.knappe-koester.com
> <http://www.knappe-koester.com> >
> 18 Bradco Street
> Keene, NH
> p. 603-355-1166
> f. 603-355-2266
> bbutler@... <mailto:bbutler%40knappe-koester.com>
> The information in this message is proprietary and/or confidential and
> is intended only for the use of the individual(s) named above. This
> message should not be forwarded without permission from the author. If
> this message is received in error or otherwise by someone other than the
> addressee, please contact the author at the above number and return the
> message or destroy it. In addition, the recipient of this data agrees to
> abide by the United States Export Control of Technical Data and
> Equipment under the International Traffic in Arms Regulations (ITAR) and
> Export Administration Regulations (EAR). The recipient agrees to abide
> by these laws and their regulations not only for export and re-export,
> but for disclosure to non-U.S. citizens.
