There is also a wizard that will generate the sample code for you to modify the extended properties.
Carson
Carson
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> The read-only is not generally on the control but on the dataView
> edvQuoteHed.dataView.Table.Columns("Number01").ExtendedProperties("ReadOnly"
> ) = "True"
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> <http://www.usdoingstuff.com>
> *Quis custodiet ipsos custodes?*
> On Thu, Dec 20, 2012 at 3:52 AM, nbuckman@... <
> nbuckman@...> wrote:
> > Hello,
> > the C# code below is not working. Can anyone easily see where I have gone
> > wrong?
> > private void edvOrderDtl_EpiViewNotification(EpiDataView view,
> > EpiNotifyArgs args)
> > // ** Argument Properties and Uses **
> > // view.dataView[args.Row]["FieldName"]
> > // args.Row, args.Column, args.Sender, args.NotifyType
> > // NotifyType.Initialize, NotifyType.AddRow, NotifyType.DeleteRow,
> > NotifyType.InitLastView, NotifyType.InitAndResetTreeNodes
> > if ((args.NotifyType == EpiTransaction.NotifyType.Initialize))
> > if ((args.Row > -1))
> > EpiDataView edvOrderDtl =
> > ((EpiDataView)(this.oTrans.EpiDataViews["OrderDtl"]));
> > System.Data.DataRow edvOrderDtlRow = edvOrderDtl.CurrentDataRow;
> > EpiNumericEditor numKitDisc = default(EpiNumericEditor);
> > numKitDisc =
> > (EpiNumericEditor)csm.GetNativeControlReference("7dd65656-d0e5-4d85-840f-a7ad2cd5b67d");
> > if (edvOrderDtlRow["KitFlag"] == "P")
> > numKitDisc.ReadOnly = false;
> > else
> > numKitDisc.ReadOnly = true;
