Thanks Erik :-)
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Thu, Sep 4, 2014 at 5:06 PM, ejohnson@... [vantage] <vantage@yahoogroups.com> wrote:
Â<div> <p>The datasets (which take up the most bandwidth) in ERP 10 payloads are compressed by default. Â If you look in the web.config file and the binding configuration for net.tcp, you'll see "NetTcpCompressedUsername", "NetTcpCompressedWindows", etc. Â Which one is in use depends on whether you use Windows SSO or a username/password.</p>
We do our own serialization of datasets because the .NET version was a lot slower. Â As part of that process, we run them through the "deflate" compression library. Â Our tests showed that ERP 10 network consumption was a bit better than ERP 9 with compression enabled on both versions. Â Let me know if you are seeing otherwise.This all applies to the client app or integrations running through the .NET proxies. For web services (SOAP), compression (and the custom serialization) are not enabled to stay interoperable.
</div> <div style="color:#fff;min-height:0;"></div>
