E10 Customization to force text field to uppercase
In Part screen customization, I need to force a text field to always be entered as uppercase.
Here’s what I have so far (doesn’t work) plus I’ve tried ToUpper and several variations:
private void SetExtendedProperties()
	// Begin Wizard Added EpiDataView Initialization
	EpiDataView edvPart = ((EpiDataView)(this.oTrans.EpiDataViews["Part"]));
	// End Wizard Added EpiDataView Initialization
	// Begin Wizard Added Conditional Block
	if (edvPart.dataView.Table.Columns.Contains("CommercialBrand"))
		// Begin Wizard Added ExtendedProperty Settings: edvPart-CommercialBrand
		edvPart.dataView.Table.Columns["CommercialBrand"].ExtendedProperties["Uppercase"] = true;
		// End Wizard Added ExtendedProperty Settings: edvPart-CommercialBrand
	// End Wizard Added Conditional Block
Before Field Change Event Handler on the Part data View. run .ToUpper() on ProposedValue.
Or bettter yet a BPM Pre-Processing on ChangePartNum method.
I tried this… it compiled but didn’t function properly. I queried the record, changed the value and it left it lowercase. Did I misunderstand your suggestion?
private void Part_BeforeFieldChange(object sender, DataColumnChangeEventArgs args)
	// args.Row["FieldName"]
	// args.Column, args.ProposedValue, args.Row
	// Add Event Handler Code
	switch (args.Column.ColumnName)
		case "CommercialBrand":
			try {
					if (edvPart.Row > -1)
						if ((args.Row["CommercialBrand"].ToString()) != "")
							args.Row["CommercialBrand"].ToString().ToUpper();
				catch(Exception ex){MessageBox.Show("Ownership uppercase error");}
			break;
You are not assigning the result … ToUpper() returns a string you need to assign it back to the variable. try
args.ProposedValue = ((string)args.ProposedValue).ToUpper();
I get compile errors when I enter the following:
args.ProposedValue = ((“CommercialBrand”)args.ProposedValue).ToUpper();
Error: CS1026 - line 1710 (3544) - ) expected
Error: CS1002 - line 1710 (3544) - ; expected
Error: CS1525 - line 1710 (3544) - Invalid expression term ‘)’
Commercial brand is not a valid type… I gave you the exact code you needed there.
Here’s some reading for further clarification regarding casting
My apologies. Thought I was supposed to substitute the field name (CommercialBrand) into the “string” value.
I have now put in exactly what you proposed and it worked perfectly. Thank you Jose.
I will do some reading on casting and type conversions.
Thanks again!
