As far as I am aware you do not have access to the QuoteMtl table on the Quote entry screen. We've had to add UD fields to either QuoteDtl or QuoteHed. I am not sure if this is a bug as you can see QuoteMtlInsp and JobMtl, but no QuoteMtl. When saving a Quote Material it writes it to the JobMtl table in base with no customization. So I am guessing you either need to add UD fields there, or possibly call Epicor and see if this is normal function
Hi,
I am trying to add some extended fields to the QuoteMtl table in E10. No problem adding the fields and getting the data model regenerated.
The problem comes when trying to find this fields to display them on the quote screen. The data tables exposed in the quote are list as the jobmtl table and not the quotemtl table.
Anyone know how to get these new UD fields to show in the quote material tab of the quote.
Tom
