WOW Stephen!
Thanks so much. This worked perfectly.
I just checked the history and I did get windows updates today.
Thanks again!
Of Stephen Edginton
Sent: Friday, July 15, 2011 6:25 PM
Subject: [Vantage] RE: E9: After running all day, Epicor 9 client will
not start
Try this...
Right click the client,
Properties -> compatibility mode -> change to windows XP.
Start the client it will work.
Then close client.
Into properties again and turn off the compatibility mode.
It will then work fine.
If it works it is an issue with windows updates and .net code security
caches but this is the simplest fix.
Regards,
Stephen
Behalf Of Joe Rojas
Sent: 15 July 2011 22:42
Subject: [Vantage] E9: After running all day, Epicor 9 client will not
start
Hi All,
I running Windows 7 Pro w/SP1 64 Bit.
I've been running on this laptop for over a year. Never a problem.
Now today, since 4:30PM EST, it will not start. Every time I try,
Mfgsys.exe crashes.
I doubt it matters but here is what happen just before.
While working Epicor support on a webex session, the tech deleted my
Live BPM folder from the server.
I immediately when into method directive and disabled and then enabled
all BPMs.
After that I has shut down my E9 client because it was running slow and
that was the end of it. It crashes every time.
Rebooted...still crashes.
Any ideas out there?
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
jrojas@... <mailto:jrojas%40matsinc.com>
<mailto:jrojas%40matsinc.com> | www.matsinc.com<http://www.matsinc.com>
Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not
the named addressee you should not disseminate, distribute or copy this
e-mail. Please notify the sender immediately by e-mail if you have
received this e-mail by mistake. Please note that any views or opinions
presented in this email are solely those of the author and do not
necessarily represent those of the company.
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Thanks again!
Of Stephen Edginton
not start
Try this...
Then close client.
Regards,
Stephen
Behalf Of Joe Rojas
start
Hi All,
Mfgsys.exe crashes.
all BPMs.
