Like Bill said, that works for me... I actually took it a step further and
created a BAT file on the user's machine and put a shortcut to it on their
desktop.
BAT file:
rem BAT FILE TO FIX MFGSYS
REM
cd C:\Users\%USERNAME%\AppData\Roaming\Microsoft\CLR Security
Config\v2.0.50727.312
del security.config.cch
cd C:\Windows\Microsoft.NET\Framework\v2.0.50727\CONFIG
del *.cch
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf Of
Turgeon, Bill
Sent: Friday, August 23, 2013 10:58 AM
To:
Subject: RE: [Vantage] 9.05.700B - MfgSys.exe has stopped working error
after login
Try the following:
Open the command prompt and do the following:
cd C:\Users\'UserName'\AppData\Roaming\Microsoft\CLR Security
Del security.config.cch
Del *.cch
Then try and get into E9 again - this has worked for me in the past
Regards,
Bill Turgeon
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
[mailto:
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
Behalf
Of lilj8069
Sent: Friday, August 23, 2013 10:52 AM
To:
Subject: [Vantage] 9.05.700B - MfgSys.exe has stopped working error
after login
We're having this issue on 2 users computers. Right after logging in, we
get a "MfgSys.exe has stopped working" error. The only option on the
error message is close program. If we move the error message to the
side, we are able to continue using Epicor without any issues but the
error message must remain open. I've uninstalled and reinstalled Epicor
on both of these machines and wiped out everything I could think of that
would be Epicor related in the process.
Any ideas? I don't really want to have to reimage the machines to get
this resolved and I would hope this issue could be resolved in some
other way.
John Kreger
