Engineering Workbench 5.2
No, we are not using the CRM module.
Matt Sturm
Winona Lighting
Phone: 507-454-5113 ext. 361
Fax: 507-452-8528
E-mail: msturm@... <mailto:msturm@...>
Sent: Monday, June 02, 2003 3:24 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Re: Engineering Workbench 5.2
The first time I open the Workbench it is always slower then the next time.
Are you using the CRM module?
Nancy
Sent: Monday, June 02, 2003 12:50 PM
Subject: [Vantage] Re: Engineering Workbench 5.2
I don't believe that I have seen the degradation in workstation performance
as you have mentioned, probably because most of our computers are shut down
nightly. We run a mixed environment of 98, 2k and XP. I log out of my XP
machine nightly, but usually do not reboot it during the week. I haven't
noticed anything odd when experimenting with the EWB. Except, once vantage
is closed and started again we are looking at the 1 minute startup of EWB
again.
Matt
Sent: Monday, June 02, 2003 11:12 AM
I have seen this and the more you open EWB the slower you computer
can become
One thing that I found was almost a critical thing to do is to reboot
your workstations every evening!
We are running all W2K Pro workstations and if they have not been
rebooted in several days, Vantage starts acting very flakey
Hope that helps
<http://docs.yahoo.com/info/terms/>
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=251812.3170658.4537139.1261774/D=egroupweb/S=17050071
83:HM/A=1564415/R=0/SIG=11t6t7kdo/*http:/www.netflix.com/Default?mqso=601647
84&partid=3170658>
<http://us.adserver.yahoo.com/l?M=251812.3170658.4537139.1261774/D=egroupmai
l/S=:HM/A=1564415/rand=936277933>
Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
We are going to be upgrading Vantage from 5.1 to 5.2 in a couple weeks. We
have a test database set up with 5.2.313 and Progress 9.1D. One issue we
have run into is the slow loading of the Engineering workbench. It is
about a 1 minute load time when you first start it. Then if you start it
again in the same session it is about 3 seconds.
Anyone else have the same situation? Is this the normal behavior?
I double-checked the usual virus scan exclusions, both client and server.
Everything related to vantage is excluded and the clients do not scan
network drives.
Matt Sturm
IT Administrator
Winona Lighting
Fax: 507-452-8528
can become
Hope that helps
weeks. We
issue we
It is
start it
again.
Matt
can become
Hope that helps
Nancy
again.
Matt
can become
Hope that helps
