I’ve added a BAQ report as a menu item and then added the same report as a context menu item under RMAHead.RMANum, however when I try to use it I get two error message . The first error is “Record not found” and the second error screen is “Cancelling launch. Report ID from the MenuRow cannot be found.” Anyone had this issue or know what I need to do to resolve it? Any help would be greatly appreciated!
I would guess that BAQ Reports don’t process ValueIn correctly… you may be SOL on this one… or MAYBE a customization to read that value in may work
Jose, Thanks for the response. That’s a bummer. I’m not super hot at customizations, so this might be above my skill level.
