Epicor 9.05 - OE Management/OE Explorer Install
Thank you for the reply Heather.
I was able to get the install started and then it gave me an error that
sounded like it was not compatible with the out of the box version of
9.05.
I installed the 700 service pack first and then the OE Management
installed fine.
It could be that during the installation of 700, I stopped all the
appservers and databases but I can't remember.
Of hmhahn_nivug
Sent: Friday, June 01, 2012 9:26 AM
Subject: [Vantage] Re: Epicor 9.05 - OE Management/OE Explorer Install
Hi Joe,
Not sure if you figured this out yet or not but I worked with Epicor on
this and I learned the following:
They said not to install OEM from the Epicor 9.05 for OpenEdge CD that
you received because there were problems with it. They told me to
download the OEM executable from EpicWeb located under Epicor 9 ->
Downloads -> Version 9.05.600 -> Third Party Products -> OpenEdge ->
10.2a -> Windows -> 64-bit -> OEM102A64_nt.exe. Before they installed
this executable they shutdown all of the databases and appservers and
the OE Admin Service. To do this they went into the
oe102a\properties\conmgr.properties file (make a copy of original just
in case) and set each of the database's autostart values to false and
you can go into the oe102a\properties\ubroker.properties (again make a
copy of original just in case) and set each of the appserver's autostart
values to 0 and set the OE Admin Service to Manual. Then reboot the
server and that should keep the databases and appservers and the OE
Admin Service from starting. Or if you have the PET installed and
working in a 32-bit environment it's as easy to connect to the database
and appservers in your 64-bit environment as right-clicking on the
Progress Explorer node in the PET, clicking on Add Progress Server...,
type in the server name, user and password, check the Reconnect at
startup checkbox only, and click OK. Now you can stop and start the
AppServers and Database from this PET tool (don't forget to stop the OE
Admin Service too from the 64-bit server too). Then you can install OEM
hopefully without any problems. I hope this helps you!
-Heather
"hmhahn_nivug" <heatherh@...> wrote:
> Hi Joe,
> I ran into the same error message and figured out that if you STOP the
AdminService for OpenEdge 10.2A and then try to run the setup.exe
program it will allow you to continue on with entering the Serial Number
and Control Numbers. Although, when I do enter them and click Accept and
then Next, the program freezes up on me...Anyone have any ideas on why
this is happening and what I could do to fix it? I have a call in to
Epicor to see if they can help me. If you run into the same issue I'll
let you know if I find out any more information on it....
> Thanks,
> -Heather
Joe Rojas <jrojas@> wrote:
> > Hello,
> > I'm installing Epicor 9.05 on our new server as we start our
migration
> > from 9.04.
> > My Epicor server is running Windows Server 2008 R2 SP1 x64.
> > Can I install OE Management/OE Explorer on the server?
> > Each time I try I get an error:
> > Error Code: -5011 : 0x80040702
> > Error Information:
> > >SetupNew\SetupDLL.cpp (510)
> > pAPP:OpenEdge Management and OpenEdge Explorer
> > PVENDOR:PSC
> > PGUID:49E1150F-908E-42BB-B26B-15B38B1E5931
> > $12.0.0.58849
> > @Windows XP Service Pack 1 (7601) IE 9.0.8112.16421
> > If I can't install this on the server then what are the OS
requirements
> > for install it? Can it go on Windows 7 x64?
> > Joe Rojas | Director of Information Technology | Mats Inc
> > dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
> > jrojas@ | www.matsinc.com Ask us about our clean, green and
beautiful matting and flooring
> > This message is intended only for the individual named. If you are
not the named addressee you should not disseminate, distribute or copy
this e-mail. Please notify the sender immediately by e-mail if you have
received this e-mail by mistake. Please note that any views or opinions
presented in this email are solely those of the author and do not
necessarily represent those of the company.
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Hello,
I'm installing Epicor 9.05 on our new server as we start our migration
from 9.04.
Error Information:
PVENDOR:PSC
$12.0.0.58849
If I can't install this on the server then what are the OS requirements
Hi Joe,
I ran into the same error message and figured out that if you STOP the AdminService for OpenEdge 10.2A and then try to run the setup.exe program it will allow you to continue on with entering the Serial Number and Control Numbers. Although, when I do enter them and click Accept and then Next, the program freezes up on me...Anyone have any ideas on why this is happening and what I could do to fix it? I have a call in to Epicor to see if they can help me. If you run into the same issue I'll let you know if I find out any more information on it....
-Heather
--- In vantage@yahoogroups.com, Joe Rojas <jrojas@...> wrote:
> Hello,
> from 9.04.
> Error Information:
> PVENDOR:PSC
> $12.0.0.58849
Hi Joe,
Not sure if you figured this out yet or not but I worked with Epicor on this and I learned the following:
They said not to install OEM from the Epicor 9.05 for OpenEdge CD that you received because there were problems with it. They told me to download the OEM executable from EpicWeb located under Epicor 9 -> Downloads -> Version 9.05.600 -> Third Party Products -> OpenEdge -> 10.2a -> Windows -> 64-bit -> OEM102A64_nt.exe. Before they installed this executable they shutdown all of the databases and appservers and the OE Admin Service. To do this they went into the oe102a\properties\conmgr.properties file (make a copy of original just in case) and set each of the database's autostart values to false and you can go into the oe102a\properties\ubroker.properties (again make a copy of original just in case) and set each of the appserver's autostart values to 0 and set the OE Admin Service to Manual. Then reboot the server and that should keep the databases and appservers and the OE Admin Service from starting. Or if you have the PET installed and working in a 32-bit environment it's as easy to connect to the database and appservers in your 64-bit environment as right-clicking on the Progress Explorer node in the PET, clicking on Add Progress Server..., type in the server name, user and password, check the Reconnect at startup checkbox only, and click OK. Now you can stop and start the AppServers and Database from this PET tool (don't forget to stop the OE Admin Service too from the 64-bit server too). Then you can install OEM hopefully without any problems. I hope this helps you!
-Heather
--- In vantage@yahoogroups.com, "hmhahn_nivug" <heatherh@...> wrote:
> Hi Joe,
> Thanks,
> -Heather
> --- In vantage@yahoogroups.com, Joe Rojas <jrojas@> wrote:
> > Hello,
> > from 9.04.
> > Error Information:
> > PVENDOR:PSC
> > $12.0.0.58849
> > jrojas@ | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
