OpenEdge 10.2A SP3 install on Windows 2008 R2 64bit?
I'm installing Epicor 9.05.601b from version 9.04.506c.
I can't get the Admin Service OpenEdge 10.2A to run as a Service. I keep getting the following message when I try to start it manually.
'The Admin Service for OpenEdge 10.2A service on Local Computer started and then stopped. Some services stop automatically if they are not in use by other services or programs.'
The server version I'm doing the installation on is Windows 2008 R2 64bit.
Here are the steps I've take on the server.
Remove the previous version 9.04
1. Removed Progress 9.04 and OpenEdge 10.1c. Rebooted.
2. Unistalled Crystal Reports runtime XI R2 runtime.
3. Unistalled Epicor 9.04 client. Rebooted.
Install 9.05 (all opnededge and epicor software is 32bit)
1. Install Crytsal 2008 runtime.
2. Install Openedge 10.2a (reboot).
3. Once server started stopped OpenEdge service.
4. Install OpenEdge 10.2a SP3 (reboot).
5. Once server started stopped OpenEdge service.
6. Installed OpenEdge 10.2a hotfix 9 (reboot).
7. On startup OpenEdge service is running fine.
8. Install Epicor 9.05 server software (reboot).
9. On startup OpenEdge service is running fine.
10. Install Epicor 9.05.601 Service Pack.
11. Install Epicor 9.05.601b Patch (reboot).
12. On startup OpenEdge Admin Service fails to start.
Has anyone else came across this yet?
--- In vantage@yahoogroups.com, "mseal" <mseal@...> wrote:
> We had same issue with same response from support.
> we upgraded to .601 then to .601a
> be careful, depending on your OS and dB version, SP release in both case has been very buggy and missed a lot of files, specifically for the data conversion portion.
> Motty
> --- In vantage@yahoogroups.com, "precisionwirecomponents" <eackerson@> wrote:
> > Success! Thanks a ton!
> > -Eric
> > --- In vantage@yahoogroups.com, Jose Ferrer <ferrerj@> wrote:
> > > Hi
> > > We had the same issue, I opened a call and they told me the error during the installation is ok.
> > > In order to start the Apps you need to change the logging setting to "Verbose" (in the broker and the agent of each App), also change the "Broker log file threshold size" to 5000000 and the max number of logs files to 10 (you should be able to change this number if you want). This is a "known" issue with OpenEdge.
> > > Regards
> > > To: vantage@yahoogroups.com
> > > From: eackerson@
> > > Date: Tue, 5 Oct 2010 20:08:50 +0000
> > > Subject: [Vantage] OpenEdge 10.2A SP3 install on Windows 2008 R2 64bit?
> > > We've been attempting to update our 9.05.600c install to .601 and .601a for the better part of a week. The first step in the instructions is to update OpenEdge from 10.2A SP2 to 10.2A SP3. While running this update we got an error:
> > > "Unexpected error when trying to set permissions, errno 2."
> > > Initially I wasn't too concerned, because the OpenEdge installation does complete and eventually I can go on to install HF9, 6.01 SP, 6.01a Patch and even today's hotfix. The updates install, the conversions finish but no matter what my appservers just wouldn't start. They start and then stop almost immediately, with no useful logging of any sort. I tried installing and reinstalling .601 and .601a a few different ways and none of them will allow the appservers to start. As a test, I rolled back my OpenEdge back to SP2 and sure enough now I can run 601a.
> > > My question ... (finally) ... has anyone else with Win2008 R2 64bit been able to install OpenEdge 10.2A SP3 without an error?
> > > I've tried installing it from RDP, from the console itself, I've run it as administrator and even reset the folder to 'Everyone' NTFS access. If I had known this would run on SP2 I'd have saved myself the week of aggravation.
> > > Just curious!
> > > Thanks,
> > > Eric
Just curious!
Eric
Hi
Regards
Just curious!
Eric
-Eric
--- In vantage@yahoogroups.com, Jose Ferrer <ferrerj@...> wrote:
> Hi
> Regards
> From: eackerson@...
> Just curious!
> Thanks,
> Eric
Motty
--- In vantage@yahoogroups.com, "precisionwirecomponents" <eackerson@...> wrote:
> -Eric
> > Hi
> > Regards
> > From: eackerson@
> > Just curious!
> > Thanks,
> > Eric
