Hello my dear colleagues!
I am trying to install the Epicor Client into a Workstation, and when finishing the process, it is reporting this error message:
Automatic update failed for the following reason: 1 is not a supported code page. Parameter name: codepage Contact Your System Adminstrator
Thank you Aaron for your kind response. Let me tell you the workstation does not have SQL SERVER installed on it. The base language for the workstation must be Spanish Language[Colombia], however, the Epicor Server is in English Language, along with MS SQL SERVER.
Really, it has been only one out of twenty installations with this sort of problem.
Thank you so much for your kind support! However, the issue has not been solved yet, because the error continues to appear when installing the Epicor Client.
