Epicor functions maintenance library is demoted but edit button is not enabled to do some changes in a function or not allowing to add new function
Epicor functions maintenance library is in demoted state, but edit button is not enabled to do some changes in a function or not allowing to add new function. It was working perfectly fine, I already have added many functions, have done changes, but today, I’m facing this issue, after the demoting of a library, I can’t edit and add new custom code function.
What could be the reason of this problem, and what are the step(s) to resolve this issue.
Thanks in advance for your time and guidance.
Regards
Are you multi-company? If you are, you may not be in the company where the function was created.
What John said. I’ve been bitten by this many times. :woozy_face:
Did you make any changes to your Epicor user ? If you did, make sure your user belongs to the groups Function Admin & Developer.
Thank you :heart_eyes:
