Erp function in Kinetic
Hello,
do you know why I can not see Epicor function library in the Erp-function widget. the Epicor funciton library is empty. but I already created a library in the epicor function maintenance.
thanks,
Eddy
Did you promote the function library to production? In the Actions menu.
Hello,
no, i did not do that?
regards,
Eddy
it is working.
regards,
Eddy
Just in case someone else is having this same problem, I’ve gotten bit by this a few times, including the last hour or so…
Another reason it doesn’t show up in the erp-function properties under ERP Functions Library - you didn’t give security to your company in Function Maintenance. When you’re testing/developing a function and calling it from “Schedule Epicor Function”, it will work just fine. But if you didn’t add the company on the Security tab in Epicor Functions Maintenance, it won’t show up in the Erp-Functions widget.
