<div id="ygrps-yiv-837879706yiv0408774724ygrp-text">
<div style="color:rgb(0, 0, 0);font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:12pt;background-color:rgb(255, 255, 255);"><div>FYI - Here is my plan of action notes for implementing Scheduling which I have done in a Test environment</div><div> </div><div><font face="Times New Roman">
Setup labor resources as named. This is setup on each employee by select
a labor resource group.
Inactivated generic labor resources. (Resource Grp Maint, Resources, details, Inactivate non-emps,
destroyed equipment and tooling and set live emps and equipment to Finite
Capacity)
flexo dies,cylinders, and various TOOLS alone.
Only inactivate if destroyed or no longer in use.
Setup labor resources to finite capacity. (This can be done as one of the
last steps).· Operators
are set to Finite Capacity.· Inactivated
generic labor resources·
Create new capabilities. (ProdMgmt, Sched, Setup, CapMaint DMT)· Add employees to capabilities. (ProdMgmt, Sched, Setup, CapMaint,
Resources; manual entry)·
Add capabilities to operations. (Operation
Maint) (DMT)o Change primary
defaults to new capabilities. (Sequence 50) (DMT)o Set sequence 50 as
primary, setup and prod. (DMT)·
Manually delete resource groups from operations.
(delete generic labor)·
Delete all un-firm jobs. (JobEntry
manual deletion)
unfirm and un-engineer it in order to delete the demand then put cursor in job
number field and click delete.
Fix Open Job records.
engineered. (Set both columns to FALSE
then DMT) o Sort run by OpSeq
and run multiple times if needed.o Recheck released and
engineered with change descriptions.·
Unlocked schedule for all jobs.
(Job Entry, uncheck “Unlock†in sched priority section)The next 2 bullets were
skipped in pilot but must be done in Live·
Fix Open Quotes·
Fix Part MOMs ·
Set equipment resources to finite. (This can be done as one of the last
steps). (Resource Grp entry)·
Setup a process set to run nightly. 1st – Calculate Global
Scheduling Order, 2nd – Global Scheduling. (Process
Set Maint)
<div>
Sent: Monday, July 21, 2014 2:29 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Epicor Scheduling
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-3119
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
Sent: Monday, July 21, 2014 2:06 PM
To: vantage
Subject: [Vantage] Epicor Scheduling
Epicor 9.05.702a Progress 64bit
I am currently working on utilizing the Scheduling functionality for Epicor. We have installed Epicor over 2 years ago and have been doing the scheduling manually with no constraints and resource groups set to infinite instead of finite. I am about to change all of this by adding the capabilities layer to the system and adding actual production employees to capabilities and setting them all to finite. I will also be setting all the equipment to finite as well and then add these capabilities to operations. My question for everybody is: Is this the best way to add constraints to the scheduling system? Is anybody else out there doing things differently in terms of setting up scheduling? If so, how are you doing it and why is this way working out better for you as apposed to other plans.
</div>
<div id="ygrps-yiv-837879706yiv0408774724yqt22752"><div style="height:0px;color:rgb(255, 255, 255);"></div></div>
</div>
<div id="ygrps-yiv-837879706yiv0408774724yqt65086" class="ygrps-yiv-837879706yiv0408774724yqt7626324970"><div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-mkp #ygrps-yiv-837879706yiv0408774724hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-mkp #ygrps-yiv-837879706yiv0408774724ads {
margin-bottom:10px;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-mkp .ygrps-yiv-837879706yiv0408774724ad {
padding:0 0;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-mkp .ygrps-yiv-837879706yiv0408774724ad p {
margin:0;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-mkp .ygrps-yiv-837879706yiv0408774724ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-sponsor #ygrps-yiv-837879706yiv0408774724ygrp-lc {
font-family:Arial;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-sponsor #ygrps-yiv-837879706yiv0408774724ygrp-lc #ygrps-yiv-837879706yiv0408774724hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-sponsor #ygrps-yiv-837879706yiv0408774724ygrp-lc .ygrps-yiv-837879706yiv0408774724ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724activity span {
font-weight:700;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724activity span span {
color:#ff7900;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724activity span .ygrps-yiv-837879706yiv0408774724underline {
text-decoration:underline;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 .ygrps-yiv-837879706yiv0408774724attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 .ygrps-yiv-837879706yiv0408774724attach div a {
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 .ygrps-yiv-837879706yiv0408774724attach img {
border:none;padding-right:5px;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 .ygrps-yiv-837879706yiv0408774724attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 .ygrps-yiv-837879706yiv0408774724attach label a {
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 .ygrps-yiv-837879706yiv0408774724bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 .ygrps-yiv-837879706yiv0408774724bold a {
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 dd.ygrps-yiv-837879706yiv0408774724last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 dd.ygrps-yiv-837879706yiv0408774724last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 dd.ygrps-yiv-837879706yiv0408774724last p span.ygrps-yiv-837879706yiv0408774724yshortcuts {
margin-right:0;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 div.ygrps-yiv-837879706yiv0408774724attach-table div div a {
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 div.ygrps-yiv-837879706yiv0408774724attach-table {
width:400px;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 div.ygrps-yiv-837879706yiv0408774724file-title a, #ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 div.ygrps-yiv-837879706yiv0408774724file-title a:active, #ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 div.ygrps-yiv-837879706yiv0408774724file-title a:hover, #ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 div.ygrps-yiv-837879706yiv0408774724file-title a:visited {
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 div.ygrps-yiv-837879706yiv0408774724photo-title a, #ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 div.ygrps-yiv-837879706yiv0408774724photo-title a:active, #ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 div.ygrps-yiv-837879706yiv0408774724photo-title a:hover, #ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 div.ygrps-yiv-837879706yiv0408774724photo-title a:visited {
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 div#ygrps-yiv-837879706yiv0408774724ygrp-mlmsg #ygrps-yiv-837879706yiv0408774724ygrp-msg p a span.ygrps-yiv-837879706yiv0408774724yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 .ygrps-yiv-837879706yiv0408774724green {
color:#628c2a;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 .ygrps-yiv-837879706yiv0408774724MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 o {
font-size:0;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724photos div {
float:left;width:72px;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724reco-category {
font-size:77%;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724reco-desc {
font-size:77%;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 .ygrps-yiv-837879706yiv0408774724replbq {
margin:4px;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-mlmsg select, #ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 input, #ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-mlmsg pre, #ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 code {
font:115% monospace;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-mlmsg #ygrps-yiv-837879706yiv0408774724logo {
padding-bottom:10px;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-msg p#ygrps-yiv-837879706yiv0408774724attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-reco #ygrps-yiv-837879706yiv0408774724reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-sponsor #ygrps-yiv-837879706yiv0408774724ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-sponsor #ygrps-yiv-837879706yiv0408774724ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-sponsor #ygrps-yiv-837879706yiv0408774724ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-text {
font-family:Georgia;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-text tt {
font-size:120%;}
#ygrps-yiv-837879706 #ygrps-yiv-837879706yiv0408774724 #ygrps-yiv-837879706yiv0408774724ygrp-vital ul li:last-child {
border-right:none !important;}
