Hi everybody,
Just wondering if there was a chance someone could assist in getting a simple update working in ESC 10.0.700.
Here's a basic rundown of our system/integration into Epicor. We have a front-end ERP system that uses Epicor more as a back-end ERP system to handle the financial side of things as our company is very production-driven, and therefore required branching out to design packages such as SolidWorks, Altium, etc. Each job has a jobcode created in our front-end system, which in turn creates a project in Epicor.
This is done using the .dll's through visual studio. Now, we've made the decision to move over to using Epicor Service Connect to handle these project updates/creations. We create an XML into a folder that an input channel monitors, that is then converted to an XSD and a workflow is triggered from that point.
For this example, let's just assume we're updating an existing project. My workflow is as follows:
1. Start
2. GetProjectByOurJobcode (conversion)
3. ProjectImpl.GetByID (method)
4. CheckThatProjectExists (condition)
5. UpdateProject (conversion)
6. ProjectImpl.UpdateExt (method)
7. Finish
Please understand that I am aware that the UpdateExt is for multiple result updates, and the Update is for a single result. However, for reasons unknown even by support staff, it seems that only UpdateExt works in our case.
Now, this is where I'm unaware what I'm supposed to do. If I set a literal value in step 5 then I have no issues with it updating with said literal values. However, I need the data that's in the jobcode.XSD to be mapped to the update request xsd before the update. This is where I begin to trip up. Here is what I've tried:
- Converting from our XSD to Update Request XSD using conversion in between steps 5 and 6.
- Converting from our XSD to GetByID Response, then mapping the GetByID Response to Update Request XSD, after step 4 and in place of step 5.
Update Request hasn't had any fields mapped to it since service connect doesn't see it as a continuation of the chain but the start of a new one
- GetByID response hasn't been pushed through as an input and therefore, as with the previous attempt, it is seen as a new chain.
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-3119
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
Sent: Sunday, March 15, 2015 8:08 PM
Subject: [Vantage] Epicor Service Connect 10.0.700 simple update
Hi everybody,
1. Start
7. Finish
* Converting from our XSD to Update Request XSD using conversion in between steps 5 and 6.
* Converting from our XSD to GetByID Response, then mapping the GetByID Response to Update Request XSD, after step 4 and in place of step 5.
These quite clearly result in errors because the fields that Epicor requires are blank in our XSD, however if we had received a project dataset back from Epicor, then it would have all it's fields mapped correctly. Here are the problems I presume exist with the examples:
* Update Request hasn't had any fields mapped to it since service connect doesn't see it as a continuation of the chain but the start of a new one
* GetByID response hasn't been pushed through as an input and therefore, as with the previous attempt, it is seen as a new chain.
Any assistance in this matter is greatly appreciated, I've google'd endlessly, and have read through the manual more times than I can count.
Kind regards,
Dave.
