Error message when start vantage
Thanks Troy
It works
--- In vantage@y..., "Troy Funte" <tfunte@e...> wrote:
> Sharma,
> Uninstalling Progress on that Client PC, and then reinstalling
using the \progress\netsetup\setup.exe can usually remedy that
problem. I'm told that the \netseup\setup.exe approach to installing
progress can be a bit more reliable than using the
VantageClientSetup.exe approach.
> Troy
> From: sharma_nalini
> To: vantage@y...
> Sent: Tuesday, July 02, 2002 9:52 AM
> Subject: [Vantage] Error message when start vantage
> HI
> I having problem to start vantage for one of my user profile at a
> computer where everyone else can start vantage.
> The error message i get after 30-40 setting is
> "Error occured while creating control frame:Splitter 1
> Class not registerd
> Error code: 0x80040154(5898)"
> When i click ok i get another message
> "Unable to realize control frame widget (4025)"
> When i press ok again system try again to start progress but give
me
> same error message again and again.
> Does any one has any clue?
must have already linked your email address to a yahoo id to enable
access. )
Builder and Crystal Reports and other 'goodies', please goto:
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
HI
Class not registerd
When i press ok again system try again to start progress but give me
Sharma,
Uninstalling Progress on that Client PC, and then reinstalling using the \progress\netsetup\setup.exe can usually remedy that problem. I'm told that the \netseup\setup.exe approach to installing progress can be a bit more reliable than using the VantageClientSetup.exe approach.
Troy
HI
Class not registerd
