Error when trying to print AR Invoice
I gave a bunch of users access to the AR Invoice Tracker, however, when they try to print an invoice they get this error message:
Menu ID UDCSG008 is not valid for the current user
Any ideas on how to fix?
I think that error sounds familiar, check the Security tab in Menu Maintenance for that particular Menu ID and make sure these users have access.
I believe that the print option in the tracker is actually calling the ‘Mass Print AR Invoices’ module - so you would have to give them security access to that menu item as well if you want them to be able to print.
I selected the ‘Allow Access to All Groups/Users’, still doesn’t work
Already gave them access to this, still errors out
We reported a similar error to Epicor Support, people with the CRM license can’t print, only people with the full license are able to print since the upgrade from 10.2.200 to 10.2.400.
