Bruce
AutoCad-Design Web Format
p:\av15\avwin\avwin.exe &1 -s p:\av15\avwin\dv.scr
p:\av15\avwin\avwin.exe &1 -s p:\av15\avwin\dp.scr
My view script simply does a ZOOM-FIT command, my printing script rotates 90
degrees so the drawing fills the page, the pc is set to portrait printing
but the drawing will come out landscape.
Dv.scr
ZOOM-FIT
Dp.scr
rotate 90
print
rotate 0
Quit
I also maintain AutoVue outside of my Vantage installation.
Patrick Winter
From: Bruce Hoversland [mailto:bruce.hoversland@...]
Sent: Wednesday, March 16, 2005 8:17 AM
Subject: RE: [Vantage] File Association DWF
In the document association screen what did you put for the view command? I
have the executable with "&1" after it, is that right
Sent: Wednesday, March 16, 2005 5:26 AM
Vantage's document association for a dwf using AutoVue works for
viewing,
printing, batch printing, etc....
Patrick Winter
sSc Specialty Screw Corporation
Vantage 6.10.514, Progress 9.1D08, Windows 2003 Server, Crystal
8.5.3.975
Sent: Tuesday, March 15, 2005 4:45 PM
I see what you are shooting at. I never tried to set up the document
association for this file type. It certainly doesn't seem to work. In
case
it helps, we view our inventor drawings through vantage as *.idw using
voloview express, because idw files are the default drawing file created
by
Inventor.
Sent: Wednesday, 16 March 2005 8:07 AM
That's the one I'm using, do you know if there is anything special in
the view command of the document association?
Sent: Tuesday, March 15, 2005 1:54 PM
DWF is a drawing format supported by Autodesk Inventor. To view it, you
need the Autodesk Express Viewer (available free). Here is a link to the
free download from the Autodesk team.
Cheers
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2404513&CMP=
ILC-GN9219645015
Sent: Wednesday, 16 March 2005 3:46 AM
Subject: [Vantage] File Association
Has anyone tried a file association with a DWF file?
If you got it to work what did you use for a view command?
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
have
and
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Dv.scr
ZOOM-FIT
Dp.scr
rotate 90
rotate 0
Quit
Patrick Winter
viewing,
Patrick Winter
8.5.3.975
case
by
Inventor.
Cheers
ILC-GN9219645015
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
have
and
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
