There is a fixed quantity check box on materials, I want the same thing on assemblies. Use case, I have serial tags cut on the laser. I have a job qty of 3, I need 3 different part numbers cut. If I could make the quantity 1 and have fixed quantity, I could make that work correctly on the job. As of right now, we can’t and have to try to use work arounds to get different serial tags cut.
Did you ever get a fix/work around on this??
I did not, it’s still a thorn in my side that I don’t have a good solution for.
Ahhh Shame. It seems a logical progression…
Won’t setting the min-max-multiple as the same value provide fixed order quantities? That’s how we handle it.
We don’t use MRP, everything is made on one job with one BOM.
That would explain it then.
