Fixing entry errors
It doesn't matter. As long as the labor record from MES is complete (the user didn't Start Activity without Clocking Out or Ending Activity) the only place to edit the record is from Vantage's Labor Entry.
--- On Thu, 8/28/08, jimlmm24521 <jimlmm24521@...> wrote:
Subject: [Vantage] Re: fixing entry errors
Date: Thursday, August 28, 2008, 2:58 PM
We will be using MES......... ..
Thanks....
--- In vantage@yahoogroups .com, "bpbuechler" <pbuechler@. ..> wrote:
> That would be from Labor Entry within the Vantage application.
> You get there from the following menu:
> Production Management>Job Management>General Operations: Labor
Entry
> The difference is if you have MES, labor is recorded by clocking
into
> something (Indirect, Setup, Production, Rework) from a MES
> workstation. If you have MES, then Labor Entry "Edit" on the
> application side is where you would make changes. We have MES, so
we
> changed the name of the menu item to be Labor Edit...makes more
sense.
> However, if you do not have MES, then the same place where you
record
> labor is the same place you make the edit - Labor Entry
> Note - If you are attempting to edit Nonconformance Qty, you can't.
> Nonconformance creates an Inspection transaction record that
cannot
> be simply deleted. It must be processed through Inspection
> Processing (where you could pass it back to the job).
> Thanks
> Patty Buechler
> --- In vantage@yahoogroups .com, "jimlmm24521" <jimlmm24521@ > wrote:
> > What is full license labor entry?? Is it different from labor
> > entry?? We are in the latest version of Vantage
> > --- In vantage@yahoogroups .com, Robert Brown <robertb_versa@ >
> > wrote:
> > > Edit the trans using Full license labor entry.
> > > --- On Thu, 8/28/08, jimlmm24521 <jimlmm24521@ > wrote:
> > > From: jimlmm24521 <jimlmm24521@ >
> > > Subject: [Vantage] fixing entry errors
> > > To: vantage@yahoogroups .com
> > > Date: Thursday, August 28, 2008, 8:45 AM
> > > Say a shop floor employee enters the wrong quantity or reason
> code
> > on
> > > a job they were working on. What is the best way to fix these
> > types
> > > of errors??
Say a shop floor employee enters the wrong quantity or reason code on
a job they were working on. What is the best way to fix these types
of errors??
of errors??
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...>
> From: jimlmm24521 <jimlmm24521@...>
on
types
> of errors??
Production Management>Job Management>General Operations: Labor Entry
The difference is if you have MES, labor is recorded by clocking into
application side is where you would make changes. We have MES, so we
changed the name of the menu item to be Labor Edit...makes more sense.
However, if you do not have MES, then the same place where you record
Nonconformance creates an Inspection transaction record that cannot
Patty Buechler
> --- In vantage@yahoogroups.com, Robert Brown <robertb_versa@>
> > --- On Thu, 8/28/08, jimlmm24521 <jimlmm24521@> wrote:
> > From: jimlmm24521 <jimlmm24521@>
code
> on
> types
> > of errors??
We will be using MES...........
Thanks....
Entry
into
we
sense.
record
cannot
> Thanks
> Patty Buechler
> code
> > on
> > types
> > > of errors??
Sorry... "Full license" versus the reduced cost licenses of MES.
It is the regular Labor Entry application within Vantage.
As long as the record is complete (in that they didn't Start Activity in MES but haven't yet Clocked Out or Ended Activity), you know the employee ID and the PAYROLL date associated with the labor entry record, you can view it and edit it in Labor Entry.
Rob
Date: Thursday, August 28, 2008, 12:56 PM
--- In vantage@yahoogroups .com, Robert Brown <robertb_versa@ ...>
> --- On Thu, 8/28/08, jimlmm24521 <jimlmm24521@ ...> wrote:
> From: jimlmm24521 <jimlmm24521@ ...>
on
types
> of errors??
