FRx Setup Questions
FRX is pretty easy to use, but support from Vantage is non-existent there. Call FRx is you have support thru them and you will get very good support.
Scott Obel
Todd Caughey <caugheyt@...> wrote:
Thanks. We eventually got it working with help from Epicor and a LOT of help from FRx. Ended up blowing away the SQL Server database abd recreating it and also found there were problems in Vantage 6.1.533 in the FRx Export that required manual "fixing" of field sizes in the SQL database EVERY TIME it was exported. Epicor found a note for one of the fields but it took FRx support to examine a log file and find the second field. I was informed earlier this week that patch 535 has fixed this problem.
So now the hurdle is for our CFO to learn the report designer.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Scott
Sent: Friday, April 28, 2006 4:38 PM
Subject: RE: [Vantage] FRx Setup Questions
Try using the default U name and W words of "frx" and "manager"
respectively. I can send you screen shots of the setup if that helps.
Note that 6.5 FRx has many bugs on Vantage and that you will want to update
to 6.7 to get past these. It has taken Epicor TWO months to figure out how
to get that for me, but with some help from FRx it is now on the way. FRx
will not ship it to you, so you must go thru your reseller (I assume Epicor)
to get the update if you need it.
Scott Obel
Todd Caughey
Sent: Wednesday, February 22, 2006 1:53 PM
Subject: [Vantage] FRx Setup Questions
I am having a few difficulties getting FRx to work. Has anyone here
installed and configured it successfuly without using a consultant? Did the
3/7/2002 installation guide work as written or are there some "unwritten"
steps that are required?
Specifically in the SQL Server setup of the FRxData database. I can not
connect to it when setting up the DSN and it seems there should be some
users set up for the database. I had this working (up to a point, once)
only after I set up some users (nothing about this in the instructions so I
was guessing at what I was doing). I actually got it to export data once.
But when trying Report Designer and setting the default company it kept
asking for a username and password and nothing worked (not network login,
not Vantage, not sysprogress, not manager/manager, not network
administrator...nothing). It said I need a valid user/pass to log into that
company. The Fabrikam training companies work OK though.
I eventually blew away the FRxData database and started again but now am
stuck with the DSN setup.
If someone has been through this process ahead of me...what am I missing?
Todd Caughey
Harvey Vogel Mfg. Co.
The information contained in this E-mail message and any documents which may
be attached are privilaged and confidential, and may be protected from
disclosure.
Please be aware that any use, printing, copying, disclosure or dissemenation
of this communication may be subject to legal restriction or sanction. If
you think you have received this message in error, please reply to the
sender.
< http://groups.yahoo.com/group/vantage/files/>
SPONSORED LINKS
Manufacturing
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufacturing> &k=Manufacturing+software&w1=Manufacturing
+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=P
da+database+software&w5=Database+management+software&w6=Database+marketing+s
oftware&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA> software
Membership
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Manufac> &k=Membership+database+software&w1=Manufac
turing+software&w2=Membership+database+software&w3=Database+mortgage+softwar
e&w4=Pda+database+software&w5=Database+management+software&w6=Database+marke
ting+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ> database software
Database
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manufactu> &k=Database+mortgage+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+software&
w4=Pda+database+software&w5=Database+management+software&w6=Database+marketi
ng+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A> mortgage software
Pda
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufacturing+> &k=Pda+database+software&w1=Manufacturing+
software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pd
a+database+software&w5=Database+management+software&w6=Database+marketing+so
ftware&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> database software
Database
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Manufac> &k=Database+management+software&w1=Manufac
ting+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw> management software
Database
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manufact> &k=Database+marketing+software&w1=Manufact
uring+software&w2=Membership+database+software&w3=Database+mortgage+software
&w4=Pda+database+software&w5=Database+management+software&w6=Database+market
ing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw> marketing software
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage < http://groups.yahoo.com/group/vantage>
" on the web.
* Your use of Yahoo! Groups is subject to the Yahoo!
< http://docs.yahoo.com/info/terms/> Terms of Service.
_____
SPONSORED LINKS
Manufacturing <http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA> software Membership <http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ> database software Database <http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A> mortgage software
Pda <http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> database software Database <http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw> management software Database <http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw> marketing software
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage> " on the web.
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
_____
SPONSORED LINKS
Manufacturing software Membership database software Database mortgage software Pda database software Database management software Database marketing software
YAHOO! GROUPS LINKS
Visit your group "vantage" on the web.
I am having a few difficulties getting FRx to work. Has anyone here installed and configured it successfuly without using a consultant? Did the 3/7/2002 installation guide work as written or are there some "unwritten" steps that are required?
Specifically in the SQL Server setup of the FRxData database. I can not connect to it when setting up the DSN and it seems there should be some users set up for the database. I had this working (up to a point, once) only after I set up some users (nothing about this in the instructions so I was guessing at what I was doing). I actually got it to export data once. But when trying Report Designer and setting the default company it kept asking for a username and password and nothing worked (not network login, not Vantage, not sysprogress, not manager/manager, not network administrator...nothing). It said I need a valid user/pass to log into that company. The Fabrikam training companies work OK though.
I eventually blew away the FRxData database and started again but now am stuck with the DSN setup.
Todd Caughey
The information contained in this E-mail message and any documents which may be attached are privilaged and confidential, and may be protected from disclosure.
Please be aware that any use, printing, copying, disclosure or dissemenation of this communication may be subject to legal restriction or sanction. If you think you have received this message in error, please reply to the sender.
Scott Obel
Todd Caughey
Todd Caughey
disclosure.
sender.
SPONSORED LINKS
Manufacturing
Membership
Database
Pda
Database
Database
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage <http://groups.yahoo.com/group/vantage>
" on the web.
<http://docs.yahoo.com/info/terms/> Terms of Service.
_____
-Todd C.
Scott Obel
Todd Caughey
Todd Caughey
disclosure.
sender.
SPONSORED LINKS
Manufacturing
Membership
Database
Pda
Database
Database
_____
YAHOO! GROUPS LINKS
" on the web.
_____
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
