Guess I have a reason to move to 809 now. Yes, I did set up the email process, and attached it to a schedule. Thanks for your help!
Calvin Dekker <calvin@...> wrote: If you're not on 809 patch, there is a known bug with email formats.
The message processes but cannot be sent.
I don't have the MPS # but Virginia knows of this bug. It's fixed in
809 patch and works well.
On a side note, do you have a Process running for the sending of messages?
HTH,
Calvin
-------Original Message-------
Date: 9/1/2006 11:22:06 AM
Subject: RE: [Vantage] Vantage 8.0: Global Alerts
Thanks. I did run telnet <your.smtp.server's.ip.address> 25, and I did
receive a response.
Mark Wonsil <mark_wonsil@...> wrote: > According to support this means
my email setup in the company is not
send mail through your email server. Check to see if your mail server allows
relayed mail from your Vantage server's IP address.
To check this out, go to your Vantage server, open a DOS windows (Start |
Run
| CMD) and type:
and see if it is allowing a connection. If not, then it's a relaying issue
and
you'll have to give permission in your mail server.
Also, if your server requires SMTP authentication, that can cause issues too
Mark W.
Get your email and more, right on the new Yahoo.com
HTH,
Calvin
receive a response.
> correct. However, I have validated that it is indeed correct. SoYour mail server for one... It is best practice to not allow just anyone to
> support says that something else might be blocking the traffic.
> What can I look at to see what might be blocking traffic on Port 25?
Run
| CMD) and type:
and
Mark W.
