OK, the error I'm getting now is, "Unable to read header information from the convmap file 'p:\oe101b\convmap.cp'"
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Stephen Freeman
Sent: Thursday, June 26, 2008 4:16 PM
Subject: RE: RE: RE: RE: [Vantage] Re: Good News (maybe?) for Report Builder Users Moving to Vantage 8
Tried this
P:\oe101b\bin\prorb32.exe -convmap p:\epicor\convmap.cp
And got the same results.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Podlin, Michael
Sent: Thursday, June 26, 2008 3:56 PM
Subject: RE: RE: RE: [Vantage] Re: Good News (maybe?) for Report Builder Users Moving to Vantage 8
you can try adding -convmap f:\epicor\convmap.cp to your startup shortcut. By default the system is taking the DLC path, which in your case is the d:\epicor folder and most likely the client workstation doesn't have the same D:\ folder as the server. Just set the f:\epicor to your clients server share path/drive that they would be able to see the convmap.cp file.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>]On Behalf Of Stephen Freeman
Sent: Thursday, June 26, 2008 3:32 PM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
It exist on the server. The user does have read by not modify access. I copied the files into the server folders but I'm running it from the client.
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com [mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On Behalf Of Podlin, Michael
Sent: Thursday, June 26, 2008 3:23 PM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Subject: RE: RE: [Vantage] Re: Good News (maybe?) for Report Builder Users Moving to Vantage 8
does the file convmap.cp exsist in "d:\epicor\oe101b\"? What are it's attributes? Are you trying to run Report Builder from a client pc or on the server itself?
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com<mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com<mailto:vantage%40yahoogroups.com>]On Behalf Of Stephen Freeman
Sent: Thursday, June 26, 2008 3:00 PM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com<mailto:vantage%40yahoogroups.com>
OK guys I tried this on Vantage 8.03 and I get the following error "Unable to open convmap file 'd:\epicor \oe101b\convmap.cp'
Suggestions on how to fix this?
Sent: Wednesday, June 25, 2008 3:20 PM
Subject: RE: [Vantage] Re: Good News (maybe?) for Report Builder Users Moving to Vantage 8
I just tested this on my test server and Lonnie is correct. I was able to create a report from scratch. Have to see if I can bring over some of the 6.1 reports and get them to run. Then have to see if we can launch a report from within Vantage from a button........
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com<mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com<mailto:vantage%40yahoogroups.com>]On Behalf Of lonniedrew
Sent: Wednesday, June 25, 2008 2:59 PM
Subject: [Vantage] Re: Good News (maybe?) for Report Builder Users Moving to Vantage 8
Yes, I can confirm!
I dropped a couple of fields from the Resource table in Vantage 8
and fired away, and the Resource table doesn't exist in Vantage 6.1.
Now someone needs to find a problem with this.
C'mon, dash our hopes.
Lonnie
Tried this
Yes, I can confirm!
Lonnie
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, Todd Caughey <caugheyt@...> wrote:
> While I hope this is true my more pessimistic side recalls hearing
somewhere that "old" reports could be run in this fashion but new
development against the 10.x DB would not. If you can confirm that
an entirely new report can be created from scratch against a
progress 10.x DB I might be ready to celebrate. I can't see where
it would harm anything, being read-only, but in the long run I'm sur
we will ahve to move to CR anyway. Would make the transition pain a
lot easier though. Thanks for the find.
> -Todd C.
> Sent: Wednesday, June 25, 2008 2:44 PM
> Subject: [Vantage] Good News (maybe?) for Report Builder Users
Moving to Vantage 8
> Hey group,
> Yahoo has a problem at the moment so I couldn't search the archives
> to see if this was posted before.
> Found a short message on ProgressTalk, which described how to run
> Progress version 9 Report Builder with Progress version 10.
> It said to copy v9 bin\Prorb32.exe and one .dll to same location in
> v10, and I believe it says v9 must be installed on the same machine
> as v10.
> BY GOSH IT WORKED. Ran it from the new location on the test server
> and connected to Vantage 8 data.
> I HAVE NOT CHECKED IT OUT COMPLETELY, only connected to db and ran
a
> simple report. If anyone finds a problem, please let me know.
> Lonnie
> The message follows ---->
> RE : OpenEdge and Report Builder
> Date: Thu, 4 Oct 2007 17:23:20 +0200 (CEST)
> From: Alassane Ouattara <alassaneouatt@xxxxxxxx>
> Subject: RE : OpenEdge and Report Builder
> Ok. Thank you with all.
> --- MARTY Philippe <p.marty@...<mailto:p.marty%40groupe-
cogeser.fr>> a écrit
> > If you have a PROGRESS V9 try this :
> > copy C:\DLC9\bin\prorb32.exe in
> > C:\OE10\bin\prorb32.exe
> > C:\DLC9\bin\accugnt5.dll in
> > C:\OE10\bin\accugnt5.dll
> > then make an icone of OE10\bin\prorb32.exe and then
> > you can connect ou
> > modify report in OE .
> > Note you must have PROGRESS 9 in the local machin
> > WITH OE10 if you want this
> > to wrk.
> > The reason is that PROGRESS goes down with
> > ReportBuilder.
> > exemple Report creator : CrystalReport (
> > BusinessObject )
> > IN FRANCE we have XPrint ( perhaps
> others
> > country but don't know )
> > -----Message d'origine-----
> > De : postmaster@...<mailto:postmaster%40peg.com>
> > [mailto:postmaster@...<mailto:postmaster%40peg.com>]De la part de
> > Alassane Ouattara
> > Envoyé : jeudi 4 octobre 2007 16:25
> > À : peg@...<mailto:peg%40peg.com>
> > Objet : OpenEdge and Report Builder
> > Does there exist a version of the "Report Builder"
> > for
> > openedge ?
> > Which creator of report is it necessary to use with
> > openedge and why ?
