Scanning into Stock to Stock Transfer…haven’t tested other screens, but Warehouse is seeing it in other Epicor screens/programs. My test resulted in a little more than a 1/20 error/scan ratio.
When scanning quantities that have consecutive identical digits (ie. 11, 22, 333, 144, 551, etc.) the scan will occasionally drop one of the duplicate digits (ie. 1, 2, 33, 14, 51, etc.).
Are you using the Epicor RDP App or Epicor Mobile Warehouse? Is it just a Code39 barcode?
Can you launch a notepad app on the device and see if scanning into a different app works, if it still does the same - see if messing with the ScanWedge / DataWedge settings can help.
I’ve seen something similar with a keyboard when using an RDC connection. For whatever reason, when I type 33 by tapping the 3 (on the keypad) twice and real fast, it only goes in as a single 3.
check to see if the scanner has a setting to slow the “typing rate”
