How do I upload a DMT in Vantage 8.03?
In Epicor DMT is a separate license you have to purchase. If you have the license, then your CAM should have hooked you up with the DMT application. You log into the application the same way you log in to Epicor.
Do you know that you have the DMT license?
Is it installed?
Have you run the application and logged in?
What data do you want to upload?
I can only give you information based on my experience in Epicor DMT, but it might be relevant.
Good luck!
Hi yes we have the DMT license-
Uploading a DMT template to populate job scheduling codes.
This is in Vantage 8.03
Thanks for any help!
