Hi Shawn, this is usually done by adding a “Tracker View” to the dashboard. In dashboard maintenance right click the query and you should see “add tracker view”. It could also be done in a customization layer, but there is rarely a need for that.
Hi Shawn,
If you customize Tracker View by Right Click >> Customize Tracker View, then you will not be able to re-order the tracker controls using the up & down arrows in tracker Properties dialog.
But you still can reposition the controls on Tracker View customization.
I’ve tried the following on Epicor 10, and it worked:
Right click the Tracker View then choose “Customize Tracker View”.
Reposition the controls.
Save, on customization dialog.
Save, on dashboard screen.
Deploy.
Note that you need to re-deploy the dashboard every time you make new changes.
If this didn’t work, then try any of the following:
