How to capture BAQ parameters that use inside calculated field inside BAQ Report Designer
As part of BAQ, I’m using parameters to perform some calculations within calculated fields and we are planning to build a report using BAQ report designer. How to call this parameter inside BAQ Report Designer?
Hello, Mohd. Welcome.
Alternatively, KB0114676 gives another way to generate a report with a BAQ as the data source, with a direct inference to the BAQ Parameters using Criteria Mappings.
