How to properly invoke the SalesOrder.ChangeMake method in a post-processing method directive?
Edited - was rawtha wordy :roll_eyes:I have a post-proc method directive whose logic seems to work fine, but , I still haven’t figured out how to invoke the method to change “make direct” on the release. I have managed to stop getting errors, and the code runs logically, but “make direct” remains set regardless.
// SF_MakeSetter 0.0.14
using (var txScope = IceContext.CreateDefaultTransactionScope())
  string b = ""; // for debugging
  if  (callContextBpmData.Character01 == "runOnce" && callContextBpmData.Character02 == "reviewOrder" && callContextBpmData.Character03 != "done") // to catch pre-processing and avoid excess runs
    if (ttOrderHed.Any() && ttOrderDtl.Any() && ttOrderRel.Any()) // to avoid testing a null and getting null runtime exception
      foreach ( var od in (from d in ttOrderDtl select d).ToList() ) // loop order lines
        foreach ( var rl in (from r in ttOrderRel where r.OrderLine == od.OrderLine select r).ToList() ) // loop releases
          if  ( (from p in Db.PartPlant where p.Company == rl.Company && p.PartNum ==  rl.PartNum && p.Plant == rl.Plant && p.SourceType.Equals("M") select p).Any() ) // test for manufactured in the target plant
            if ( (from w in Db.PartWhse where w.Company == rl.Company && w.PartNum == rl.PartNum && w.WarehouseCode.Contains(rl.Plant) && w.WarehouseCode.Contains("001") && (rl.SellingReqQty < ( w.OnHandQty - ( w.SalesAllocatedQty + w.SalesDemandQty + w.ReservedQty + w.AllocatedQty) ) ) select w ).Any() ) // check stock
              try
                using (var so = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.SalesOrderSvcContract>(this.Db) ) // get the service instance
                  int oNum = od.OrderNum;
                  int oRel = rl.OrderRelNum;
                  var soTs = so.GetByID(oNum); // load my tableset
                  // almost no idea what's going on after this point!
                  for (int i = 0; i < soTs.OrderRel.Count; i++) // loop through and ...
                    if  (soTs.OrderRel[i].OrderLine == rl.OrderLine) // ... correlate my releases and orderlines
                      soTs.OrderRel[i].RowMod = "U"; // does this set the release to be updated?
                      so.ChangeMake(false, ref soTs); // is this in the right context?
                  callContextBpmData.Character03 = "done";  // added to ensure code doesn't run again if update is called multiple times for some reason
                  this.dsHolder.Attach(soTs); // from the Epicor C# guide to replace the dataset; not sure if I understand it correctly
                  so.Update(ref soTs); // update only the context of the tableset?
                  // end "no idea... section"
                  } // end using Sales Order svc
                } // end try
              catch (Exception e )
                b = b + " error " + e ;
                Ice.Diagnostics.Log.WriteEntry(b);
                } // end catch
              } // end check for stock
            } // end check if part manufactured at release plant
          } // end loop through releases
        } // end loop thorugh order lines
      } // end if Order, Dtl and Rel exist
    } // end if review & run once check
  txScope.Complete();
  Ice.Diagnostics.Log.WriteEntry("18 - completed txScope " + callContextBpmData.Character03);
  } // end txScope
I’m gonna really owe this forum after this… but any insights would be appreciated!
Lot going on there. So no errors but where does is not do what you want? Try dumping out the various datasets or variables to see what’s being set and what isn’t
I also don’t love nesting for each loops where avoidable as it adds complexity. If your target is ultimately the release level, try building out your order line release list and then iterating over that
That’s helpful. I guess combining those two ideas would mean just figuring out how to update ANY release and then only selecting the one I want to change. Just thinking “out loud” here…
I’ll try that. Thanks for the direction.
